Replacing Both Head Gaskets
Originally Posted by quizzoman
Once you get the two bolts connected to rail off you should be able to rock the rail back and forth until the each injector pops out.
Originally Posted by dubbass33
what bolts? the ones that attach the rail to the intake manifold?
The fuel rail for the injectors right???
Originally Posted by Kevin24
Ya Luke your right,the fuel lines should then lift straight up,if not try rocking the lines while lifting up.I think there is 2 bolts on each side for the fuel rail.
i got it off. thanks. now next question. it says in the haynes book that only the 1998 engines dont allow the valve cover bolts to come off. mine loosen, but then pop up and down when trying to take them out, and they dont happen to come out all the way. are they supposed to come out fully?
Originally Posted by built54
I have a 2 page write up on when I did my head swap... im sure that would help. If i had your email i could send it to you
Is it best to use OEM gasket kits and head bolts? I'm skeptical of the Ford headgaskets and the MANY revisions to attempt to get it right. I'd prefer to go all aftermarket, but don't know who or what exactly.
yes, i got the head gasket set for $174 and then the bolts are ~$42
