f150 wont idle need help
so when i went to crank my truck today, the engine would not idle cleany, it would only sputter at around 500 rpm, so i tryed to give it some gas, floored the revs would only climb to about 1700 rpm, or to about 3200 rpm where it would almost act like it was bouncing off a rev limiter at 3500 rpm. Any ideas on what the problem could be. Could it be bad gas or a small glitch, or is it something serious.
Sounds like a fuel delivery problem. If its the new style '04 you have the returnless fuel system and the pressure would be a little different than the old style. That might explain the fluctuating RPM. Be careful about running this way because Ford had a lot of problems with injectors hanging open and hydrolocking the engine on this year model.
