royal purple? amsoil?
ok everyone! im thinkin about different oils to use and im thinkin hey i dont know crap about oil! so i start reading and researching these oils , which both seem to have good product! however we all know that anybody can wright anything and make it sound good! having siad all that, are these oils really worth the extra money? and if so is there one that is truly superior to another? thanks for the input in advance.
I just put in royal purple a few days ago and have seen maybe a .5 mpg increase, but can't give any firm results for a while. I know a lot of people run mobil 1, but I found the royal purple to be a little cheaper than that. So I figured I'd give it a shot. But both are supposed to be really good.
Originally Posted by Norm
I use the 0W-30 severe service Amsoil and have never had blowby. Which one did you use?
5 W30 .. I should mention , I was contstantly pulling the truck in a warm shop from the cold when this happened - hooking it up to a snorkle and had long idle times and also my dipstick had a hole in it behind the manifold that I didn't catch till later..
Originally Posted by fla.boy
hey guys ! thanks for all the info!
Ya, people around here get their panties in a wad whenever a dino vs. synthetic oil question comes up. Some say dino works fine and don't fix what isn't broke. Others say synth gives better mileage(there's a lot of junk "science" to that IMO) and longer engine life.
If you hate changing oil and don't do any big time hauling/loads, then synth is fine, it'll save you a few oil changes. But for hauling the oil needs to be changed regularly, so stick with dino and you'll save money. I don't think either is any better at protecting your engine, it's your choice.
But Amsoil 2-stroke oil is awesome. I use it in my jetski and sleds and you get a noticeable boost in performance with less smoke. Don't know about their 4-stroke stuff though.
I am VERY happy that you have had good results from the amsoil. It must be better than honda's crap oil.
Amsoil is the best but if you are not going to use extended intervals you will be spending lots of your money. If you are going to stick with 3 - 5K intervals use Motorcraft 5W-20, an excellent oil.
