Fuel Injector
Old Apr 24, 2007 | 10:47 PM
F150SC's Avatar
Fuel Injector
I have a 01 F150 Supercrew with a 5.4 Triton, i recently replaced all four cats all four O2 sensors two coils, and am now getting a bad injector reading on the # 2 cyclinder, for dwants 120.00 for a new injector but since Ive got 120,000 on the truck Im just going to replace all of them with some Accel's or Venoms, and was wondering what the lb rating is for the stock injectors.
Old Apr 25, 2007 | 12:12 AM
jbrew's Avatar
19
Old Apr 25, 2007 | 01:05 AM
F150SC's Avatar
19? thats it, wow that is wierd. I thought they would be around 40 or more.
Old Apr 25, 2007 | 04:05 AM
rb4123's Avatar
A fuel injector is rated at lbs. of fuel an hour, not psi. 40 is your fuel line pressure measured in psi.
Old Apr 25, 2007 | 12:14 PM
Faster150's Avatar
ford runs 43.5PSI.... but if u want a set of 19lb injectors i got a set ill sell u for 50 bucks. they got less than 15K miles on em work perfectly i took em off because i needed an upgrade.
Old Apr 25, 2007 | 08:53 PM
F150SC's Avatar
Well I got ahold of Ford, and Accel ignition and they both said the same thing, I have 24lb injectors on my truck
Old Apr 25, 2007 | 09:02 PM
Kevin24's Avatar
You have 19s stock
24s require custom tuning
Old Apr 25, 2007 | 09:05 PM
torkum's Avatar
Faster150, will the 19s work on a 4.6? I'm thinking the wiring is the same. Don't need any jokes about not having a 5.4 jbrew
Old Apr 25, 2007 | 09:36 PM
jbrew's Avatar
There both very very very WRONG. There Orange right? Only 19's are orange..You can't run 24's as Kevin Explained .. You injectors look like these -
Old Apr 25, 2007 | 09:40 PM
jbrew's Avatar
No No , I never ever start that crap - I always finish it tho
4six's run 19's stock torkum..Faster has a 4sis - I mean 4six
Old Apr 25, 2007 | 10:20 PM
torkum's Avatar
Thanks jbrew I was hoping you would keep me in line. I am going to buy some injectors and send them to Linder Tech in Indy to have the set balanced. Sounds like Faster150 has what I'm looking for.
Old Apr 25, 2007 | 10:31 PM
jbrew's Avatar
Yeah , sounds like he has good set for yuh
Even the Ford 3.8L (pre 04) ran 19's
Old Apr 26, 2007 | 08:14 AM
Faster150's Avatar
5.4 and 4.6 both come with 19's which are good for up to 305FWHP
Old Apr 26, 2007 | 08:15 AM
Faster150's Avatar
a four sex with 30's! lol not 19's
