01 F-150 5.4L Triton P0125 code Insufficient Coolant Temperature For Closed Loop Fuel
2001 Ford F-150 5.4L Triton 'service engine soon' light on with OBD-II saying P0125 Insufficient Coolant Temperature For Closed Loop Fuel & dashboard temperature gauge won't raise much above cold level.
Help!!!
I have an Engine Coolant Temperature sensor (ECT) Part# F5AZ 12A648 AB onhand. Will this correct the problem? Where is this sensor located??
Help!!!
Got talked into buying the Engine Coolant Temperature sensor (ECT) Part# F5AZ 12A648 AB before the thermostat
Also, my speedometer seems to be reading much higher than normal & malfunctioning. Is that normal?
Where is the ECT located, just in case?
Is the thermostat available at any autoparts store? What's it called exactly? Where is it located?
Thanks for any assistance & patience.
It's a pretty simple repair. From your description, it seems very likely that the thermostat is the problem.
~Ed
