Anyone swear by another plug other than Motorcraft?
Whatz up MG , Yeah , that's a PC, I never liked them in the past because it didn't matter how good at programing you were , theres always something waiting around the corner to corrupt it -Oh you could spend time taking on problems as they arise if you have the patience , In theory , you shouldn't have to .
It is allot better today , I still don't trust one. Mathematically correct isn't really that much of a virtu on a PC - So what the hell good are they? - Job security
MAC's on the other hand - well , they just work
I use to use wrist straps , for little while anyway - I haven't used one in about three years - I got in the habit of discharging all my jigluhwatts via re panel of the whatever comp I'm working on - before I dive in..
However , I have forgot to before and took one out, actually the Static E went right to the power supply and trashed it - but luckily it stopped there.
I usually keep one around - That last pic of the comp I posted has a wrist clamp attached (you can see it if you look close) - see that big red clamp in the pic hooked to the housing ? I used that to discharge ..
That's my new PCM hahaa , I wish .. Whoever writes the music for these trucks is freakin awesome . It prolly took about 50 people to accomplish and many many years to proof..
That sh^ts beyond me - I couldn't do it. These computers default seamlessly , that's very hard to do in repetition ..
Latuh
Latuh
I hope this fixes it,i am going to replace the fuel pump next weekend.I think the pump is weak.When i nail it at a stop it hesitates until the rpms go up some.friggin thing!!!!!!!!!!!!!!
Let ya know how i make out.
If it doesn't work i give up!!
Hey jbrew,is the new computer workin or did ya burn it up LOL........
Hey Kevin , If it's the same after you unplug your vacume supply line, shut it down.
Connect a vac gage to the regulator vac hose , start her up and check to make sure vacume is present.
Theres quite a few tests and procedures - you need both gages(vac & pressure) to perform.
Did you go by book , you should be able to find a list in any repair manual.
The only vac line problems I have wittnesses is the pink & blue lines by the solenoids - between your battery and firewall - both of mine rubshured at one time. I cannot explain how that happened - just got old prolly....
When your testing your pump at idle - Pinch your fuel line once and watch your guage - Pressure should increase imediatly - That just tell you how quick your pumps working..
Side Note: Regulators do go bad.
Anyway I then hooked it up to the Gateway 19" and it looks great - surpisingly fast and snappy.
BUT!! It's running way to HOT - To much power in that little box - When testing for the first hour , the temp rose about 10 degrees in the den lol.
I need a bigger box for it and a few more fans -
NOPE! - No crash and burn , YET!!
I was going to pinch the line but they don't appear to be rubber and i didn't want to crush em.
Thanks,
Kevin
Keep the computer running in the winter to save on fuel
Thanks,
Kevin
That comp would keep it warm for a little while , well, until it's compromized.
Heat kills quickly , it would be history within a month - theres a 3.4 Pig processor w/hyper threading - 1 1/2 gig of memeory fillin the slots. I new there would be a heat issue , so I siliconed the prcessor and bolted a squirl cage fan directly to the top. 300 gig HD for all me diagrams/ photo's I 've picked up over the years ..
It's all stuck in a HP FormFactor 5000 shell...I'll getter right - the next time I feel like workin on it
[QUOTE=jbrew]LOL - U crack me up , well , you can pinch the fuel line on gage - that shoud be rubber
WTF... a squirrel cage fan
Well my gauges are NFG=no F^^^in good
Edit.......gonna have to find gauges tomarrow.I do have new digital voltmeter
This would be alot esier if it would break
Squirrel cage fan - http://images.google.com/imgres?imgu...%3Den%26sa%3DN
Yeah , you need good gauges - A good digital multimeter as well..
I think i found the problem
First off my last gauge i used was a POS.I bought a nice gauge and here are the results.
Idle=28psi
Idle vaccum disconected=38psi
both hold steady
I am not sure the exact method of getting max fuel pressure?
by turning the key on and of several times=35psi
Leakdown after 5min=30psi
the most i could get revving the motor=36psi
here is what my Haynes manual says
idle 30-45psi
vaccum detached=40-50
leakdown after 5min=30-40
What you think?
First off my last gauge i used was a POS.I bought a nice gauge and here are the results.Idle=28psi
both hold steady
idle 30-45psi
What you think?
