Synthetic Oil
Originally Posted by Labnerd
Your 06 Ford already has synthetic fluids in the rear end and transmission from Ford. Transmission fluids from the manufacturer will always be far better for transmission life than an after market blender that makes a fluid that gets in the ballpark with friction coefficents but never is on the money as per design perameters. Engine oil......as long as it meets Fords 930 spec, you won't find a better oil regardless of price or advertizing hype. Your money, your truck.
Originally Posted by chester8420
Better than what? What "high heat" conditions are you referring to? Your truck's thermostat keeps the engine at a constant temperature regardless of power output or ambient temp. If your engine gets hot enough to cook your engine oil (I have seen it happen) you will have a lot worse things to deal with.
engine overheating can occur in certain circumstances, and when that happens, the vast majority of information that i've read indicates synthetics will perform to a higher temperature before thermal breakdown, ...perhaps synthetic oil might prevent those worse things with which i'd deal with if i were to shut down the engine in time
i don't believe everyone needs to, much less ought to, use synthetic, hence my lack of suggestion everyone do so...i have plenty of anecdotal evidence to the contrary and i'm of the opinion that regular oils with regular change intervals are quite sufficient for engine longevity...but i'm certainly not qualified to refute scientific analysis and subsequent information that points clearly to many synthetics performing into higher temps before thermal breakdown
you are clearly quite opinionated on the topic, and i have no desire to change your opinion, i'm just offering information to ricksfx4...if you can refute it, then i stand corrected
I noticed you live in Buffalo, so I will share something from my experience in cold weather. I lived in Alaska for 8yrs and had a daily driver 3/4 ton that had to sit outside...I started off using regular Dino type oil. Then when winter came and we would get a cold snap, meaning like -10 and below (-50 and below at times), the truck would not turn over...The oil would thicken so much it just wouldn't allow it. Happened a couple of times.
Talked to some folks and it was pretty common knowledge that synthetics were a much better performer in the cold...Changed it out to Mobile 1 and it never happened again...even at 20 to 50 below...The engine always turned over and started...I used Mobil 1 and Castrol Syntec exclusively for both of my vehicles the whole time we lived there. Never a problem after that.
The conclusion I drew from that is at least in Cold weather the Synthetics performed as specified or better...While the regular oils did not. There is plenty of research out there for this...If you want a site that is specific to oils and Lubes you can visit Bobistheoilguy and you will get plenty of knowledge.
I live in the South now and use a Synth Blend...and keep it changed regularly But if I lived in Cold weather I would absolutely use pure Synthetic for the engine..at least in the winter months..I don't know how the Reg. Oils work on the Hot side but I would imagine that it is pretty stable because the thermo regulates the engine heat...But you cannot control how cold your block gets sitting at work all day or sitting overnight and synths provided the best lubricating qualities in those conditions...
I had a manual tranny and used regular fluids for that and the rear-end...But will tell you that they were very very stiff when cold...
This is from my personal experience...We bought a brand new vehicle when we were up there (not the truck) and brought it with when we moved south...We just sold it a year or so ago with 140,000 still running strong and not burning a drop of oil...
Hope this helps...
Hope this helps...
I've seen engines get so hot that they just shut off,(not computer controlled either!) and once they cool off, they crank back up. That's the evidence I have that supports my side of the story.
But FORDZGUY has a different argument that I cannot comment on. His situation is totally unrelated to anything I do. I'm gonna take his word for it, cause he has SEEN how much better the synthetic oil did.
It's great when people come here and have something to say, and try to explain their thoughts. I will admit, that when that engine overheated and melted those hoses, it RUINED the oil. I guess he should have been running synthetic!
Having an intelligent argument leads me to think more about everybody's comments. And I KNOW I've been proven wrong before.There are (occasionally) situations on the farm where "normal" oils do break down in high heat situations. (such as oil on rusted threads) I might try a little synthetic oil next time and see what happens.
Well regardless i plan on getting the diff and the tranny changed over to royal purple soon. I am hitting 5000 miles and the bgreak in oil needs to be changed. I'm also adding a mag-hytec diff cover and a tranny pan.
For a 20K$ Truck a couple hundred $ of insurance can't hurt!!
seriously check out http://www.royalpurple.com/techrp/summary.html they have data from North Carolina State university, magazines, tv shows, etc....
A good read.
A good read.
Hope this helps...
Hope this helps...
FYI -- in the old days, synthetics did have much better cold temperature flow ratings than a regular dino oil. However, with today's modern blends, these numbers are far more comparable. So close, in fact, that the difference is irrelevant except in the most extreme circumstances.
In regards to the sludge. Sludge is not formed from anything in the oil. It is formed due to moisture that the oil cannot hydrolize or the engine does not build enough heat to cook it off. The older engines ran a 160F thermostat. There's your sludge. Also, folks didn't drive 30 miles to work like we do today. Most folks drove less than 3 miles to work. Hardly long enough to cook off moisture in a relatively cool engine. Then there is also the lead from the fuels and the contamination of the oil with fuel because of the carbs used. All of this adds to the formation of sludge.
In regards to artic conditions and synthetics. The term "synthetic" is far too broad for a statement like that. Just a couple of years ago the term was used to define a PAO basestocked oil. There are very few left anymore. The PAOs will flow better at artic temps than any dino blend or dino synthetic averagely. As of today, the common PAO synthetics would be Amsoil excluding the XL7500, Royal Purple, or Redline which is a PAO/ Ester blend. The others marketed as synthetic are all now a GP III dino synthetic. You almost need a score card to keep up. But the oils you buy today are a better formulation than the oils you bought in 2000.
In regards to the high heat. If the oil has the Ford spec 929 or 930, it is tested at the same temps as any synthetic which is 302F. It does not allow the oil to oxidize or shear out of it viscosity range. It does not allow but 35 gms of high heat deposits across the life of the oil. If your oil runs at 302F, the engine is toast anyway as there is already a catastrphic failure in progress. Most of todays synthetics are a GP III synthetic. This is same oil as any dino oil out there just a little more impurities removed and a higher viscosity index. While I'm a fan of the GP IIIs, there are no magic bullets and none of the oils will make a difference in a catastrophic engine failure.
Yes...Back when I used Castrol Syntec is was a full PAO, but has since changed. The only PAO in Castrol's line-up that I know about now days is "German Castrol" at 0W-30..But it is a very thick 30W oil...Some engines love it and some don't from what I have read the Fords don't like it...
Oil has changed formulas since I lived in Alaska...IIRC...Synths still have better cold temp pour points and I would still use them if I lived in the cold.
Mobil 1 is a PAO as well correct?
since this came about right about the time their prices on 5w-20 went up, i decided to go with castrol syntec or pennzoil platinum in our gt...i know it's group III, but i can find pretty good prices on it compared to the M-1
i think i'll stay with the MC blend in my pickup since i can usually find it for a good price...i was considering going to longer intervals with a synthetic, but honestly, i think i'd rather just change it more often
Originally Posted by RICKSFX4
I just purchased my first F150 06 Screw 5.4 3V.I do alot of city driving mostly stop and go.Some of my friends tell me I should change all my fluids like Rear Axle,Transmission,Engine,and Power steering over to Synthetic because it would be less friction and everything will last longer.I have to keep this Truck for 10 Years. Is this information correct or are they clueless?I value your advice. Thank You.
