Inectors
Old 02-08-2007, 12:16 AM
FloridaCracker1's Avatar
Inectors
hey i was wanderin about some fuel injectors for the 5.4?...like which give better power etc...
Old 02-08-2007, 12:19 AM
chester8420's Avatar
If your truck is running good, you'll probably make it worse by messin with the injectors. But that's just my advise.
Old 02-08-2007, 12:45 AM
Klitch's Avatar
you CAN upgrade injectors, i have seen 30# injectors rolling around on e-bay.
Old 02-08-2007, 12:55 AM
phil6608's Avatar
You will not see any power increase buy putting in bigger injectors.
Maybe with a custom tune or a blower.Other wise its a wast of money!
Phil
Old 02-08-2007, 12:57 AM
Klitch's Avatar
Phil
not entirely untrue? higher N/A hp apps could use them. i did not say NEED / REQUIRE i said use?
Old 02-08-2007, 01:06 AM
phil6608's Avatar
Yes you can use any size you want with a proper tune. But without some other serious mods it's a waste of money.
Old 02-08-2007, 01:08 AM
ok....so if i want to make bigger power and a supercharger bein the last thing i would do to the truck...what other things are there besides exhuast,intake ??
Old 02-08-2007, 01:09 AM
Klitch's Avatar
head work? forged bottom end?
Old 02-08-2007, 06:39 AM
torkum's Avatar
check out www.lindertech.com for balanced injectors.
Old 02-08-2007, 08:37 AM
Faster150's Avatar
only way u could see performance increase is takin advantage of timing. or fixing a lean problem like i had.
Quick Reply: Inectors
