PCM codes...
Old Jun 19, 2006 | 09:57 AM
dreamsr's Avatar
Question PCM codes...
Could someone check these codes for me. My computer threw these codes over the weekend 136 and 141. What are the results?
Old Jun 19, 2006 | 10:10 AM
jward's Avatar
www.obd-codes.com
Old Jun 19, 2006 | 12:15 PM
projectSHO89's Avatar
P0136 & P0141 OBD-II codes
Both codes are indicating the PCM is having problems with its internal diagnostics for the downstream (post cat) O2 sensor.
Most likely cause will be one of the following (in no particular order):
Damaged wiring harness or connector
Bad connection due to water/dirt/etc..
O2 sensor
PCM internal fault
Start with the connector and harness inspection.
Steve
Old Jun 19, 2006 | 04:24 PM
dreamsr's Avatar
Thank you
Thanks Steve, will check that out.
