help with computer?????????
i'm trying to change the computer for the motor and my 2002 f 150 will not run with the new computer i dont know if these are plug and play or will it need to be programed to be used in my truck thank for any help you can give me
this is a flood from katrina and the pcm had some water in it not completly but i'm replacing all electric parts that have to do with saftey and drivetrain. so the pcm is one thing that i have purchased to replace truck runs pretty good with old pcm but it worries me to thinck about leaving it in there.
I would worry more about the GEM then the PCM.
The GEM does not seem to have a sense of humor about getting wet from the windshield leaks ( if it has one that is ) and if the truck had enough water in it to soak the PCM on the firewall, the GEM might have also been under water.
the pcm had some things that were burt and one of the injectors is open all the time i hope replacing the pcm will fix the injector problem but i know it may not but after i'm sure the pcm is good ( i'm taking to dealer tomorrow to have new pcm reprogramed ) then i will start to fix the other problems if any and thanks for pointing out about the gem i have not looked at that yet but will find it and if any water was in it or close i will replace it as well
got the new pcm programmed by the dealer this week and it is running great had to replace the gem and air bag module took the truck out for a drive today and everthing but the brakes are working great replaced front rotors and pads now have to replace rear and then the drive shaft and i hope to be done at that point thanks to everyone for all the help.
