455 olds...
Old Mar 22, 2006 | 08:10 PM
cyclone vampire's Avatar
455 olds...
non ford question..A buddy of mine is restoring a 78 chev 1/2 ton, he collects this and that and has a 1971 oldsmobile 88 with a 455, He wants to put in the 455 in the chev ( Chev has a turbo 400 ) I'm of the opion a 455 Pontiac engine is stronger and I'm not asll that techincal with GM, all I know is Buick, Oldsmobile and Pontiac made 455 cubic inch engines that are not all the same....
Old Mar 22, 2006 | 08:44 PM
jhoparmy's Avatar
I did this almost this exact same thing. I put a pontiac 400 into a 84 Chevy. I had to buy a adapter plate to bolt the tranny up to the pontiac motor, but it worked flawlessly. I had to put new motor mounts and change some misc wiring, but it ran very strong. Hope this helps.
Old Mar 22, 2006 | 09:11 PM
My first car was a 1969 Oldsmobile Delta 88 with the 455 Rocket motor. Let me tell you what -- that "fother mucker" moved out for a big car! Your buddy will have one potent little vehicle if he moves ahead with his plan!
Old Mar 22, 2006 | 09:19 PM
zapster's Avatar
455's have gobs of torque
should be a real sleeper
...zap!
Old Mar 23, 2006 | 12:19 PM
PKRWUD's Avatar
Of the 455's, the Olds was the best, followed by Pontiac, and then Buick, but all three were kick *** engines. The Olds had the longest stroke.
As mentioned, this swap will require an adapter plate for the tranny, and new mounts. Otherwise, it shouldn't be hard at all.
Old Mar 23, 2006 | 12:25 PM
I had a 455 1970 Olds 88 and a 455 1974 Olds 98. Both were very strong engines.
