Problem
Old Mar 12, 2006 | 06:22 PM
b_j__h's Avatar
Problem
I was jacking up my truck and the jack slipped and ended up breaking a piece of the plastic fan shroud off. Now the fan shroud is broke into about three pieces and moves around. Should I just try and secure it with some zip ties or screws, buy a new plastic shroud, or remove the moving piece exposing some of the fan (probably not the best choise).
Old Mar 12, 2006 | 06:45 PM
lees99f150's Avatar
as long as the fan is ok, pull the pieces out that may fall into the fan and see how the temp stays for a while. depending on the size of the hole it may not really effect it.
can you show us a pic of it.
this may be a good excuse to get some electric fans from Troyer.
Old Mar 12, 2006 | 07:37 PM
chester8420's Avatar
That's right!!! just tell the wife that you have to order a few parts to fix your truck!!
Old Mar 13, 2006 | 08:39 AM
PKRWUD's Avatar
Replace it.
Old Mar 13, 2006 | 12:28 PM
JMC's Avatar
JMC
25 Year Member
It should not move around. If you can secure it in a way thet will prevent it from moving and keep the blades from touching it then go ahead and do that. I will be easier just to remove it to make the repairs. If you are unsuccessful then replace it. You need a shroud if you are using the factory fan. Look in the classified ads to see if anyone is selling one. I have my old one that I am not using but I live in Canada. You could also try the local bone yards or http://car-part.com Search for a condensor/radiator mtd cooling fan. You should see some fan shrouds listed for a bout 50 bucks. Make sure you click on non interchangable parts ans use model year 97-03.
JMC
Old Mar 13, 2006 | 02:07 PM
b_j__h's Avatar
Thanks for the replies. I will try and secure it with some screws or zip ties. There are some holes on the bottom of the radiator which I can use and drill some holes in the plastic shroud and secure the two together.
