fuel pressure regulator ?
Old Sep 29, 2005 | 05:31 PM
bdenglund's Avatar
How do you remove the dang thing. I removed the round clip ring, and still couldnt get it to come out.
B
Old Sep 30, 2005 | 09:29 AM
bdenglund's Avatar
Youre kiddin me, nobody knows?
Old Sep 30, 2005 | 09:36 AM
jmeyerholtz's Avatar
there should be 2 or 3 screws holding it on
Old Sep 30, 2005 | 05:10 PM
chucks bp's Avatar
What year and engine size are you working on??
Old Sep 30, 2005 | 09:33 PM
bdenglund's Avatar
Sorry about not saying that in the first place. it is a 2000 f150 with a 5.4.
Old Oct 1, 2005 | 02:02 PM
Neal's Avatar
HI!... Are you trying to install a adjustable FPR on to your existing fuel rail? If so the "99" and up 5.4 fuel rails have a welded on non-adjustable fuel regulator. You will have to get a fuel rail off a "97" - "98" 5.4 or some earlier year 4.6 Mustamgs. They use a bolt on non - adjustable fuel regulator. You simply un bolt the one and bolt on the other.
Here's a link to where I got my AREOMOTIVE billet adjustable FPR.
http://216.242.145.16/products/product.phtml?p=14
Old Oct 1, 2005 | 05:20 PM
chucks bp's Avatar
In the 2001 service manual it says to remove the snap ring and remove the regulator no spacific details it must pull out I feel the orings are probably causing it to stick in the bore. I know when I changed my injectors some of the orings were stuck in the fuel rail and I had to use a hook too; to remove them, you would have thaught they were glued in there. for reinstalation the manual says to lube special O rings with clean engine oil and reverse the procedure. Hope this helps.
Old Oct 1, 2005 | 08:39 PM
bdenglund's Avatar
Finally got it off. Just used a pair of channellocks to help with the persuasion. Thanks though to everyone who replyed
Brett
