Can't get the fan off..... Help!
OK,,,
15 looks and no reply,,, I'll elaborate.
it is one post holding the fan to the water pump pulley and I can't figure out how to turn the fan off and hold the pulley still.. does anyone know of they are R or L hand threads and how to get that thing off????
Thanks for any help anyone can offer!!
TB
TB
take a pry bar and tap a corner it come off lefty loose righty tighty.. due to roation of the motor is CCwise. but take a pry bar and a hammer tap the corner to break it loose. then use a adjustable wrench if needed to get the fan the rest of the way off... its not as hard as everyone says
They're pretty easy to get off usually without the tool. Just get a wrench that fits the fan nut, put the wrench on the nut at twelve o clock(pointing straight up) and smack straight down on it with a hammer. a couple of times and 9 times out of ten it will come right loose. I work on police crown vics for a living and it works every time on them. Good Luck
Larry
Larry
Larry
Larry
most police crown vics use efans... as a masster of fact most all of fords cars use efans cause it helps smooth idle add power and fuel economy. why do u think most GM's use Efans... most all the new trucks and SUV's now use Efans.. then again GM's has to expands their ways to get ponies out of their pushrod motors without adding boost and keeping compression pump gas friendly
