PI Heads
Old Mar 30, 2005 | 10:41 PM
monroes's Avatar
PI Heads
Hello was wondering if the 5.4 heads would bolt on to a 4.6, i know i will need a different intake..anything else?
Also will the mustang heads work? I know the cams are different, i was planning on changing them to a set of truck comp cams.
Old Mar 31, 2005 | 12:54 AM
Faster150's Avatar
yes heads are swapable between the 2
Old Mar 31, 2005 | 08:38 AM
WLF's Avatar
WLF
With the Mustang heads you will have to get Mustang valve covers, they have a different number of bolts holding them on. Otherwise will bolt up just fine.
Old Mar 31, 2005 | 01:04 PM
Ted'98's Avatar
If you use heads that are different than your block, along with the valve covers, you'll need different stud bolts that hold the front cover to the heads.
For example, I have a romeo block and used windsor heads, so I needed studs that would fit the windors.
Old Mar 31, 2005 | 08:39 PM
monroes's Avatar
Ted were you pleased with the results from the swap. was it worth all the trouble?
Scott
Old Mar 31, 2005 | 08:41 PM
Ted'98's Avatar
Yes, definitely.
I had the heads sitting in the basement for several months, I kicked myself for not putting them on sooner.
Old Mar 31, 2005 | 09:53 PM
wittom's Avatar
Great headswap info in your link Ted. How much did you invest in the swap?
Old Mar 31, 2005 | 10:01 PM
Ted'98's Avatar
Not that much really, I was very patient and found good deals on eBay. I got brand new, 9 thread PI heads for $200, new head gaskets for ~$30. The valve covers were free from an auction I won and then sold off parts for what I initially paid.
The only other major expense was getting the head bolts.
I was careful when taking the engine apart so that I could resuse as many of the gaskets as possible (front cover, intake, valve cover, etc).
Old Mar 31, 2005 | 10:13 PM
Faster150's Avatar
do u still have ur old heads? for the 4.6... im working on boost soon so i need some non PI heads to port and i havent had much luck finding them
Old Mar 31, 2005 | 10:17 PM
Ted'98's Avatar
Faster150 - Sorry, sold those a while ago.
Old Mar 31, 2005 | 10:20 PM
monroes's Avatar
will the 5.4 pi intake work or do i need to find a 4.6
Old Mar 31, 2005 | 10:26 PM
Ted'98's Avatar
The 5.4 intake will be too wide for your 4.6 block.
Old Apr 1, 2005 | 02:25 AM
Faster150's Avatar
aww
Old Apr 1, 2005 | 06:26 AM
Ted'98's Avatar
aww
Those may have not worked for you anyway, the intake ports were ported to fit a PI intake.
Old Apr 1, 2005 | 07:36 PM
speedy46's Avatar
Registered User
I am preparing to swap the heads on my 98 4.6 right now. Email me and perhaps we can work something out. ekrugman@sbcglobal.net
