altinater
Old Oct 26, 2004 | 12:55 PM
randy_fenwick's Avatar
Unhappy altinater
i put on a new alt. it ran for 1 day, i woke the next morning to what i thought was a dead battery. so i charged it up and that i discovered was not the problem. i have no power when i turn on the egnition. it wont turn over, no dome light, headlights, radio, nothing. now it will crank over when i cross jump the cylinoid. what could it be?
Old Oct 26, 2004 | 01:00 PM
frostby's Avatar
A bad battery will not charge on an external charger... Have you ruled out the battery? What is it's resting voltage? Corrosion, and build up on your battery terminals and cables? It's not likely you blew all your fusible links and fuses at once!
Please explain crossing your solenoid over - I don't follow.
Old Oct 26, 2004 | 01:42 PM
altinater
the charger reads 5. crossing the cylinoid with a screw driver to make it fire. the battery has new cables. does the alt. have to have a ground wire ran, or does it groud itself out when you hook it up to the brackett.
Old Oct 26, 2004 | 02:23 PM
spray004's Avatar
Take your truck to Autozone or someplace like that and have them test the battery and then have them check the alternator. What kind of truck do you have?
Old Oct 27, 2004 | 12:39 AM
bdenglund's Avatar
Same damn thing happned to me 2 weeks ago. I took off the altinator and went to the local parts store (took the battery too) and had them check it. They said it was fine then checked the battery and said it was fine. Went back and put everything back on and Ill be damned the truck started right up. So I suggest making sure all the connections and grounds are good. I hope this helps.
Brett
