Lots of oil leaks...why?
Old Oct 16, 2004 | 07:22 PM
MOVEOVER's Avatar
Just had an oil leak repaired under warranty. I bought the truck a month ago with 27k miles. They replaced 19 different gaskets. I just wondered if something may have "caused" it, or maybe they just replaced lots of them as a precaution since the rear main seal was leaking.They put new trans fluid and oil in it too (for free), so that's good.:santa:
Old Oct 17, 2004 | 12:52 AM
Pestco1's Avatar
I would imagine that a lot of the seals they replaced might have been related to things they had to take off to get to the rear main seal.
Old Oct 18, 2004 | 05:50 AM
JMC's Avatar
JMC
25 Year Member
Did they do any other warranty work at the same time? I don't see 19 gaskets being required to change the rear main seal. You remove the tranny and the flexplate or flywheel and you are looking at it.
JMC
