Occasionally won't start
Old Aug 16, 2004 | 02:38 PM
pioneer595's Avatar
My driveway is on a slight incline and on occassion, with no pattern, my 4.6 won't start. I will attempt a few times and then have to wait 5 minutes and then she will turn over. The engine just won't turn over. Again, this is rather unpredictable. Any thoughts? Fuel pump relay?
Old Aug 16, 2004 | 04:04 PM
hcmq's Avatar
My truck for no reason or warning the other day didn't start. and after repeated tries at jump starting and a new battery it still wouldn't start. it turned out to be a bad starter solenoid! (An $8.00 part)
Next time your truck won't start, first makes sure it isn't a PAT's issue by turning the key to "on" and making sure the "theft" light goes out after 3 seconds. if all else is normal but it won't start get a remote start switch or a bf screw driver and while the key is still in the "on" position bridge the two large posts on the solenoid and the truck should start. If not I am not sure what is wrong!
good luck!
Old Aug 16, 2004 | 11:49 PM
temp1's Avatar
Re: Occasionally won't start
Im a little confused. Do you mean the engine does not turn over or do you mean the engine always turns over but will not start running?
Old Aug 17, 2004 | 10:42 AM
pioneer595's Avatar
Sorry... it turns over, but never engages and starts running. It is almost like fuel never gets injected.
