Heli-coil blew out
I have treaded inserts. They are not helicoils. You tap out the head, blow out the chips screw the insert in using a plug. When you remove the plug there is a tool that is used to set the insert by expanding the top.
I'd be willing to send you the tap, tool and insert(providing I have the right size) for a deposit and shipping. Deposit will be returned when I get the tools back.
similar to this
http://www.timesert.com/sprksert.html
similar to this
This sounds great.. I was told though that since I've already used a heli-coil that this is not an option?
Can I still use this kit? Where do I buy the stuff and how do I know what size?
The blown plug is the 3rd one from the front on the passenger side. Do I have to remove the head? Because if so, I can buy a junkyard head for $150.
THanks again for the help!
