Oxygen Sensor error code...Help? Po153
Old Apr 30, 2004 | 04:42 PM
mscruton's Avatar
Just brought my 1998 F150 4x4 5.4L (serial's 8th digit "L") into the Autozone folks to check my "Check-engine" light with their scanner. They told me I had error code "Po153" and that I had a bad oxygen sensor in Bank 2, Sensor One. I confirmed this code online at www.actron.com but am not sure if I should drop the $50 to replace it. My questions are: 1. While I realize the sensor "ones" are located in front of the converter, I'm not sure which side bank two is for my truck..passenger or drivers side? (Autozone told me that bank two was the passenger side, but I wanted confirmation from the "real" experts here on this forum) I'm not a mechanic so I wasn't able to locate it when I looked under the hood... 2. Should I test anything else before replacing the sensor, or should I start off by replacing the sensor and then see if it fixes the problem? Thanks, Matt
Old Apr 30, 2004 | 04:49 PM
01screw's Avatar
Bank 2 sensor 1 is driver's side upstream (before converter) sensor. O2 sensers go bad all the time, I say replace it.
Old May 1, 2004 | 11:09 PM
mscruton's Avatar
Thanks, I'll take your advice and replace it (once I find it). I'm also going to try to get rid of the annoying ABS light. From reading other posts, I'm guessing my speed sensor might be shot. So rather than taking it to a garage and paying $$$ to have it hooked to an ABS scanner, I'll just see what happens. Thanks!
Old May 2, 2004 | 12:47 PM
mscruton's Avatar
Geez. Thats pretty fast driving. How'd she handle at that speed? I've never taken mine past 75mph, but I'm more of a Sunday driver. You probably wouldn't like driving behind me.
Old Jul 31, 2004 | 11:17 AM
Capt Caper's Avatar
AutoZone also told me with the P0135 I have the sensor in front of the cat on the pass side and behind the cat were bad.
I changed both and the light will come back on after resetting it.
So I must change the sensors on the Drivers side also? Is there just one or is there two more?
I have an 1999 4.6 F150 Lariet. Auto trans.
Old Dec 6, 2007 | 11:28 PM
ctony1's Avatar
02 sensor
Ford has recently made the discovery that once one 02 sensor goes bad, that you should replace the others.
Old Dec 7, 2007 | 08:21 AM
Quintin's Avatar
Source?
Old Dec 8, 2007 | 07:03 AM
openclasspro#11's Avatar
maybe the other cylinders upper-not necessarily the ones after the cat -phil
