5.4 idle problem?
Old Apr 10, 2004 | 04:50 PM
LBC150's Avatar
5.4 idle problem?
hi guys,
when my truck is warm and is idle, it is at about 600-650 rpm. the truck has a slight vibration threw it when it is idling this low. i don't know if its normal or not. i have no drivability issues with it whatsoever. i used to have a 01 4.2L and i never had a problem. i don't remember what it idled at exactly but it never vibrated, so i never paid too much attention. if someone could tell me if this is normal, and if not, what is wrong and how to fix it that would be great. thanks.
Old Apr 10, 2004 | 05:48 PM
Johngs's Avatar
I would start with the IAC valve. Usually just cleaning it will work, but it may also have to be replaced.
Do a search on IAC* if you need more info.
Old Apr 11, 2004 | 01:03 AM
01screw's Avatar
Lot of these trucks have a slight vibration while at idle.
Old Apr 11, 2004 | 01:56 AM
LBC150's Avatar
thanks, i will check out that valve and see if it makes a difference.
maybe i am just not used to the v8...i dunno.
Old Apr 11, 2004 | 10:27 AM
Crick's Avatar
mine had a vibration that started once then went away after a week or so. I chalked it up to bad gas.
60k+ and still smooth as a babies bottom
