5.4l Block Heater
Old Jan 5, 2004 | 11:33 AM
SMIGGS's Avatar
5.4l Block Heater
I'M POSTING FROM ALBERTA CANADA WHERE IT IS A BALMY -45c WITH THE WINDCHILL. I WAS WONDERING IF ANYBODY OUT THERE HAS INSTALLED AN ADDITIONAL BLOCK HEATER TO THEIR 5.4L. THE TRUCK ALREADY HAS ONE FROM THE FACTORY BUT THE BLOCK IS SO BIG THAT ONE BLOCK HEATER DOESN'T HELP MUCH ESPECIALLY WHEN IT IS REALLY COLD. I KNOW OF PEOPLE WHO HAVE 2 BLOCK HEATERS ON 351 MOTORS AND ALL THAT WAS REQUIRED WAS THE REMOVAL OF THE FROST PLUG ON THE OTHER SIDE OF THE BLOCK. ANY HELP WOULD BE APPRIECIATED!
Old Jan 5, 2004 | 05:48 PM
JMC's Avatar
JMC
25 Year Member
Smiggs,
If you care to look on the other side of the block you might find that the Starter is in the way of the rear plug. The middle one is hindered by the motor mount and the front one has the A/C compressor in front of it. Try 0W20 oil. Seriously, the starter might have room behind it for a block heater. Measure your OEM with the plug attached to the heater for clearance.
It must be installed so the element doesn't touch the block on the inside.
Regards
Jean Marc Chartier
Old Jan 5, 2004 | 06:11 PM
SMIGGS's Avatar
I WILL HAVE TO HAVE A LOOK. THANKS FOR THE REPLY JEAN! HOW DO YOU TAKE THE FROST PLUGS OUT OF THE BLOCK?
Old Jan 5, 2004 | 07:03 PM
JMC's Avatar
JMC
25 Year Member
Use a punch or a drift to knock it sideways and then pull it out with vice grips.
JMC
