Changing Fuel Filter?
Old Nov 8, 2003 | 09:52 PM
BALLIN4JC's Avatar
Question Changing Fuel Filter?
I HAVE A '99 V8 5.4 F150. IT STARTS UP FINE BUT WON'T STAY RUNNING UNLESS I REIVE THE ENGINE. IT WANTS TO DIE WHENEVER I COME TO A STOP. I THOUGHT IT MIGHT BE THE FUEL FILTER BECAUSE IT HASNT BEEN CHANGED IN A WHILE. DOES ANYONE HAVE AN IDEA OF WHAT IT MIGHT BE. ALSO HOW CAN I FIND THE FUEL SUPPLY MANIFOLD SO THAT I CAN RELIVE THE FUEL PRESSURE.
Old Nov 8, 2003 | 11:01 PM
Yankee7985's Avatar
Sounds like you have a dirty IAC valve. Easily removed and cleaned or replaced.
Good luck
Old Nov 9, 2003 | 10:45 AM
suvdrvr's Avatar
On the passengers side fuel rail (on the engine), there is a Schrader valve which you can depress and it will de-pressurize the lines
Old Nov 9, 2003 | 02:17 PM
temp1's Avatar
Just a note, you might wan't to make sure the engine is NOT HOT if you dump gas into the engine department using this valve...
