How much for an engine swap?
Old Oct 9, 2003 | 05:56 PM
eposey's Avatar
A 4.6L isn't near that much is it?
Would It be possible to throw in a 32V 4.6L Cobra Engine in there?
Are there any other engines that would be that clean of a swap?
Old Oct 10, 2003 | 05:51 PM
eposey's Avatar
What about the engine thats in the classifieds right now? Its a Lightning engine. Would that be possible without shelling out a ton of money on top of the price of the engine?
Old Oct 10, 2003 | 11:12 PM
LeanNCut's Avatar
Why not just go for it. If it doesn't work you can always brag you were the first LMAO.
Old Oct 11, 2003 | 01:36 PM
eposey's Avatar
I would do it if I was positive on what I was doing and had a lot more knowledge of engines than I do. I would have to have the work done in a shop.
Old Oct 11, 2003 | 02:14 PM
Intel486's Avatar
It's possible but you're looking at having to get a lot of stuff...
The best bet would be to start searching for a wreaked truck that you want the engine out of and then grabbing the drivetrain out of it. Engine, tranny, computer, sensors, etc.
Old Oct 12, 2003 | 03:40 AM
Johngs's Avatar
Saw this thread, you might be interested:
https://www.f150online.com/forums/sh...66#post1100866
Old Oct 12, 2003 | 11:46 AM
LeanNCut's Avatar
When's the ProCharger coming? Ooops, I didn't mean to end this thread .
Old Oct 12, 2003 | 04:24 PM
mikemike98's Avatar
You might want to try a mustang site I,m sure someone has mod.
a mustng by now.
If you don't find anything there and you don't want to reseach
what you need your self. Just drive it to ford or another shop and for a couple hundred they should be able to give you a parts list.
Old Oct 12, 2003 | 09:37 PM
eposey's Avatar
Yes, I know about the supercharger. I was looking for an engine that had a little more to work with.
Old Oct 12, 2003 | 09:43 PM
lifeguardjoe's Avatar
I know for a fact that you can interchange our engines(or even a built one)
All you would need is the proper brackets.
Old Oct 13, 2003 | 07:00 PM
eposey's Avatar
And how do you know this for a fact? By brackets, do you mean engine mounts?
Old Oct 14, 2003 | 07:51 PM
LeanNCut's Avatar
He's done it, duh!
Old Oct 15, 2003 | 03:47 PM
iron horse's Avatar
check car-part.com
You can find 97- 03' low mileage f150 4.6 or 5.4 engines with everything you need from around $1200 to $1800. Good luck.
Old Oct 15, 2003 | 06:06 PM
eposey's Avatar
Can anyone verify that a 5.4L or 5.0L V8 would work in my truck as long as I had the correct harnesses and engine mounts?
I am confused because above I was told that only the 4.6 would work.
Old Oct 15, 2003 | 07:23 PM
Johngs's Avatar
I dont think they make the 5.0L anymore.
As far as my limited knowledge of the engine bay and the engines themselves go, going by just what I have seen on these boards:
I have seen several threads about swapping the 5.4L into 4.6L trucks.
Therefore I would *think* you could put a 5.4 into your truck if you can find kits to make the 4.6 work. It would be more expensive obviously, also, the 5.4 may be too big...although that doesnt make sense in my mind because I think the trucks are basically all the same (as far as the size of the actual truck and the frames and so on).
But I would wait for someone who really has more experience shows up.
