Hearing a noise and don't know what it is
I have a 98 F-150 with a v-6. I keep hearing a noise everytime I push on the gas pedal. It sounds like a metal on metal rattle. It doesn't start right away. It starts a second or two after I accelerate. But then it stops after a second or two. I doesn't do it after I have accelerated to full speed. The truck is running fine. Is it just my imagination? Anyone have an idea what it could be? Thanks
I have the same type of noise in my truck. Happens just as you describe. I haven't made the time to track it down, but I might bank on a heat shield of some sort.
I had the same type of thing happen on an old Nissan truck...fixed it with some bailing wire. No cost...no rattle!
Let us know what you find out.
It's most likely the heat shield for a catalytic converter. They can rust and become loose or you can also get sand or stones trapped between the shield and pipe.
If the shield is loose, Ford suggests a band clamp be installed to hold the shield in place. If there are stones, you should be able to spray water in there to get them out.
On my truck, I had a loud rattle at 1,200 RMPs for a while. Turns out that a 2"x3" metal ID tag had rusted loose and was rattling around between the heat shield and the pipe.
