electric fans
Old Mar 13, 2003 | 07:34 PM
camdenlake's Avatar
Advantage?
I know on my motorhome i saw a huge increase in power and millage when i changed to an electric fan have you folks see these increases on the F150. I have a 99' f150 5.4L i play ofroad quite a lot in the summer plus i travel down thorugh the souther us in the july august time frame. I am trying to come up with a way to get more power (hey why not) and better the millage at 85+ cents per liter any thing can help. So let me know
Thanks for the input
Josh
Old Mar 13, 2003 | 08:17 PM
JMC's Avatar
JMC
25 Year Member
The claims are around 15 HP at the rear wheels. I must have gotten that because when the motor is cold I can chirp them off idle by nailing the gas. 33's BFG MTs with 3.55 gears. I could not before the install.
JMC
Old Mar 13, 2003 | 08:20 PM
camdenlake's Avatar
great
What kit did you use or was it a diy? Did you see much millage change (even with the big meats)
Old Mar 13, 2003 | 08:56 PM
JMC's Avatar
JMC
25 Year Member
I have the kit supplied by Mike Troyer's Performance Products Inc. I don't measurethe MPG on my truck. Look at my sig, it isn't worth it.
JMC
Old Mar 13, 2003 | 09:05 PM
camdenlake's Avatar
Info
how would i get a hold of that company?
thanks
Josh
Old Mar 13, 2003 | 09:17 PM
Neal's Avatar
Cool
HI!... MIKE TROYER at PERFORMANCE PRODUCTS 1 (540) 862-9515. His kit is basically what you see in my pics in my other post, but he uses different fan controllers.
Old Mar 14, 2003 | 06:58 PM
Richard D's Avatar
Question
To all who have the Flex-a-lite installed and tow
I would like to hear from any and all who have installed teh flex-a-lite fan kit on ther truck with the 5.4 w/A/C and who tow a boat or trailer. How does the fan work does it keep the temp normal and has anyone had any problems with there trucks getting hot with this setup? Also I went to Flex-a Lite's website and downloaded the install directions and they seem a bit confusing now it may be becuase i don't have the fan here to visually see all the parts but how hard is it really to install I am mainly concened with the wiring aspoect of it.
Thanks,
Richard D.
https://www.f150online.com/galleries....cfm?gnum=2479
Old Mar 15, 2003 | 08:55 AM
B-Man's Avatar
Cool
Richard D -
Read here first: Original Flex-A-Lite Fan Install Write Up
The fans (there are 2 of them) will definitely cool your truck, no matter what the circumstances. They move way more air than the stock fan.
As far as the wiring, it is all pretty straight-forward, right up 'till you get to the AC compressor connection.
Read the thread, there is a wealth of info regarding the whole install (because there were a couple of installs going on simultaneously in the thread).
Get the fans - you'll be glad you did.
Besides, if you get stuck, POST !!!
Good luck !!!
Old Mar 15, 2003 | 11:10 AM
Richard D's Avatar
B-Man
That is a good thread I did a search yesterdy and foud it and have saved it into my favorite for referance next week or so when i get the fans. I do have a question though,I see that some have said something about putting a manual switch in for turning the fans off while on the freeway as they are not needed to cool,but this has confused me a bit because if you are on the freeway and the air flow is suffecient to cool the truck would not the fans shut off on there own if you have the tmp set for the fans to kick on at 190 and the cooling system does not get that high while on the freeway why would you need a switch to turn the fans off. Also where do you get this lighted swicth if it is needed to do this task? So you think this fan setup will be ok to handle towing a boat in 100 + dgree weather during the summer months?
Thanks,
Richard D.
Old Mar 15, 2003 | 01:25 PM
hapynzap's Avatar
My FAL fans run on the freeway if I have the A/C on. I dont have a problem with that. Man, my AC runs cold now! heh.
I just got back from a road trip to CA and the only time my fans ran (w/o AC on) was when I would stop at a rest stop they would come on for like 30 seconds when I stopped.
Right now with temps only in the 80's here the only time my fans run are when I'm sitting in traffic or a drive thru. My fans usually are not running especially when I'm moving.
Old Mar 15, 2003 | 03:42 PM
Richard D's Avatar
So at what temp does everyone have there fans coming on and how do you set that. Sorry for all the questions but I will be installing one soon and I am trying to get all the info I can ahead of time so I dont' stumble when doing the install.
Thanks,
Richard D.
Old Mar 15, 2003 | 04:56 PM
hapynzap's Avatar
I went with the FAL factory setting. I got an idiot gauge in my 98 and when it hits about 1/3 it comes on. I may try and tweak FAL ECM some as summer approaches.
I've heard 192* is best.
Old Mar 15, 2003 | 07:10 PM
Richard D's Avatar
Is 192* what the FAL factory setting is?
Richard D.
Old Mar 15, 2003 | 07:24 PM
hapynzap's Avatar
I'll have to call them to check. Monday
Old Mar 15, 2003 | 07:27 PM
Richard D's Avatar
Was it in the instructions what it is set at?
Richard D.
