Ticking?
Old May 23, 2002 | 10:21 PM
kutter752's Avatar
Question Ticking?
I was sitting in a drive through and i heard a ticking like i was low on oil. I just had it changed about 1000 miles ago and i am not low. Does anyone know what this might be...sounds like a lifter or a rod..but i dont know
Heath
Old May 24, 2002 | 11:51 AM
kutter752's Avatar
TTT
Old May 24, 2002 | 12:41 PM
Talleywacker's Avatar
Suspended For Violation of Vendor Rules
You only hear this at idle or do you hear this at cruising speed or w.o.t. ?
I have a ticking sound also but only when my truck dips to ~500rpms.
It could be a number of things....
Old May 24, 2002 | 03:37 PM
kutter752's Avatar
It is at idle and about 1500 rpm and that is it i dont hear it anyother time...hmmm...my engine is going to die
Old Jun 1, 2002 | 05:57 AM
bwana's Avatar
Lightbulb
The ticking is from the fuel injectors and is perfectly normal. Use a stethoscope or screwdiver to listen to them and you'll see.
Old Jun 1, 2002 | 11:24 AM
I am aware of the loud injectors that we have... I don't know if this would be the problem... use a stethoscope like bwana says.
you can hear it with your ears if you just get close and touch an injector with your finger... and listen, see if the sound is in sync with the pulse feel of the injector.
Old Jun 1, 2002 | 10:27 PM
houndawg's Avatar
it could also be a leaking exhaust manifold
Old Jun 2, 2002 | 12:05 AM
kutter752's Avatar
Thanks for the replyes guys...i will try that...i dont have an exaust leak
Old Jun 2, 2002 | 11:21 PM
kutter752's Avatar
sorry
Old Jun 3, 2002 | 08:25 AM
sig239intx's Avatar
I had a clicking in my trucks turns out it was a converter that the ceramic in side had broke apart. Got lucky on this one as they have to warranty converters for 70.000. DAVID
