Stock air filter
stange;
The plastic thing is a cone that helps to reduce turbulence at the end of the stock air filter. It is not on the K&N but is a integral part of the stock filter. Without this cone, I think there would be more turbulent air flow at the end of the K&N filter when used in a stock air cleaner housing. If you modify the housing by cutting it, I think that the turbulence would be eliminated. GlennMc.
stange
I think that you are worried for nothing. But, if you want, give it a wack and see if it comes off. A little duct tape and your new K&N should be equipped with a cone and ready to go. Seriously though,I wouldn't bother with it. I have a K&N in my truck and noticed no difference with it other than that it can be cleaned (and cleans up very well with K&N products ) and will save you money in the long run. GlennMc.
Take a look at my site... www.southsideracing.org , then click on "F150 air box modification" I recently wrote a short page about how to remove the air filter housing.
