Rpm @ 65 Mph
Old Oct 19, 2001 | 02:36 PM
XLT-Sport's Avatar
Rpm @ 65 Mph
I was just wondering, how many rpms is everyone running when they're going steady at 65mph. I run at 1700 RPMs when I'm cruisin at 65. Just wondering if this was 'normal'.
Old Oct 19, 2001 | 03:09 PM
f150freak's Avatar
Keeping in mind that your RPMs will vary depending on the rear gear ratio and tire size, I am running excactly 2,000 at 65 mph
3.55 gears and undersized tires
Old Oct 19, 2001 | 09:55 PM
lightningcrashz's Avatar
well......
I think I run at 2100-2200 rpms going 65mph.I have a heavy 4x4 and slightly oversized tires(265/75-16s)I have had the truck at a scale and it wieghs in close to 5,000lbs with me and my huntin stuff.Just takes more rpms to go the same speed as a lighter truck.
oops I forgot to tell ya my gear ratio is a 3.55
Old Oct 20, 2001 | 07:15 PM
XLT-Sport's Avatar
correction
sorry...My gear ratio is 3.55 and my rpms are at 1850 at 65.
Old Oct 22, 2001 | 04:09 PM
acadianbob's Avatar
V-6, 5 speed, 3.55, 265/70/17s (stock) 2,000 RPM @ 65 mph. it appears to me that everything else being equal, the autos turn at lower rpms than the 5 speeds. have a friend with same tires and gears, his turns 1,700 rpm @ 65 but it's an automatic. is this consistent with what any of the rest of you are seeing?
p.s. i don't think it matters what engine you have. rpm should be a function of tires, gears, and possibly the transmission type.
Old Oct 24, 2001 | 09:22 PM
Claudia's Avatar
Post
I run about 2000 or just below.
Old Oct 25, 2001 | 02:21 AM
RILOATM's Avatar
I have a 5 speed with 265/75 BFG AT's and a 3.08 Rear end. I turn about 1840 RPM's in OD. In 4th gear i turn around 2200. Actually, i'm probably a little lower then that, since my speedo is off from the tires.
Old Oct 25, 2001 | 02:34 PM
SQZDONY's Avatar
Exactly 2500 RPMs at 65 mph. 4.10's.......
