Another oil leak with pic. Please give insight
Soooo, another leak, great. I noticed this because of one reason only. Every time I'd shut the drivers door after driving it I'd hear a hiss type sound. Like when dripping water hits a hot surface. However, it only started making the sound with in the last week. It's obviously a drop of oil hitting the hot exhaust.
There are no drips on the ground (because the oil hits the exhaust) and I've checked and double checked, I'm not low on oil.
Obviously this wouldn't have anything to do with it, but the only thing that has changed, was I switched from Pennzoil full synthetic (which I had been running for the past 60k miles) to the motorcraft 5W20 blend. Are there different swelling agents by chance?
Anyway, here's a pic, it's on the drivers side just before the transmission.
I'm about to drive 1300 miles, will I be ok or should I get this taken care of prior?
If it's losing oil like you claim I am sure it would show on the dipstick. It looks as if the valve cover gasket could be the culprit. Have you checked the the VC bolts to see if they are loose? I would not hesitate to drive it anywhere in the US.
If you DON'T have it checked I hear Valvoline MaxLife and M1 HM oil are some great oils and just might help you out.
If it were mine and I had the money I would get it looked at.
Go here and ask around;
www.bobistheoilguy.com
By the way, what was the outcome for your oil leak?
Being I am disabled now my cousins or friends help me with my OCIs. They overpoured and it overflowed from the funnel and worked its way down the engine.
BTW, I am currently using Havoline 5W30 conventional oil. It really pi**es off the 5W20 oil worshipers.
Kind of them to help, but that's quite a scare for nothing haha. What advantages do you find with that oil? I've heard this engine can take just about anything. It's mainly those 5.4 guys that have to be picky.
Before becoming disabled I had lived in FL for 25 years. I would let Ford do all of my oil changes. At the end, before moving back to La., my son helped me change my oil, using MC 5W30. My engine was a bit more quieter.
If I ever use a 5W20 it will either be MS5K or Castrol SynBlend. These 2 oils are the only oils in 5W20 that make my engine run quiet.
The 4.6 and 5.4 NEED the 5W20 for the top end of the engine. The 4.2 was originally designed to use 5W30 and in all of its years of production the tolerances and clearances have never changed.
Try some 5W30 in your engine. You will surprised how quiet it runs.
Thanks, always get that confused. Local ford dealer said not to use 5w30. But they're just going by their books and never give a good answer for something like that.
I'll keep the mc 5w20 blend in there now. Cleaned up the seam that appeared to be leaking and put some rtv on it. It's not gushing and I highly doubt I'd lose half a quart between OCI's. I'll bring it to a ford dealer in Florida and have the leak addressed. I'm not ok with just dealing with it. I'd rather have the leak properly fixed even if it means a bit extra $$.
I'm doing well, thanks!
