97 4.2 F150 Coolant leaking into oil?
Hi Im trying to figure out why the antifreeze is leaking into the oil
Ok I ordered a new long block which came wth everthing new except had to transfer the Waterpump, timing cover, lower and upper intake manifold, oil pan from the old engine. Installed it and antifreeze was leaking into oil. So ripped out lower intake gasket replaced with another new one. Still antifreeze leaking into oil. Now did another check drained all oil out left oil plug out and just fill the coolant resevour up with coolant and without starting the engine up its antifreeze is pouring out the oil pan.what could be my problem?
Replace the timing cover gasket and upper intake gasket. Get the ones from Ford not the Felpro ones. Your issue is one that plagues the 97 and early 98 4.2s. The gaskets were made 1 mm too small so over time they shrink when the motor cools and this lets coolant leak into the #1 & #4 cylinder which can cause the motor to hydrolock. Do a google search on hydrolock 4.2 and you will find tons of info.
And I went to fill the radiator overflow with antifreeze and antifreeze is still going into the oil pan.
This is with the engine turned off not running.
Can anyone please help me out?
From bad headgaskets? Its a new long block
Could it be a crack in the block?
