What fixed your V6 with system too lean bank one and two codes?
Old Mar 7, 2011 | 07:24 PM
scrap08's Avatar
I have a 2001 F150 V6 and getting system too lean bank 1 and bank 2. What part did you replace to fix these codes?
Old Mar 7, 2011 | 08:23 PM
jgger's Avatar
There are a bazillion threads on that subject, search p0171/174.
But mine was plenum gaskets and isolator bolts- 10 times out of 9 that will be it. Do a total vac line check first and PCV system. If that dosen't do it then it's probably the gasket/bolt thingie.
Good luck
Old Mar 7, 2011 | 08:55 PM
sampson01's Avatar
plenum gaskets are the number 1 problem ... i do about 20 of these a year in the ford 4.2s
Old Mar 8, 2011 | 02:47 AM
dirtyd88's Avatar
Another for intake gaskets and isolator bolts.
Old Mar 8, 2011 | 10:58 PM
Raptor05121's Avatar
If you have the composite intake, its the isolator bolts. If you have the aluminum intake, try replacing the gasket and checking PVC lines. Oddly enough, mine was an exhaust leak/bad cat.
