Volant F.I.P.K
Old May 31, 2001 | 06:05 PM
mike150's Avatar
Cool Volant F.I.P.K
You can see these at www.volantperformance.com.I looked at all the fipk and decided to get this one since it was made to have the filter is up against the fender opening to maybe get some cool air from the there.the filter has an opened end.also it looked nice and seemed to have a good mounting system.Will let you know how it installed and any results when I get it.
------------------------- 99 SILVER XLT/REG.CAB/4.2/5SPD/3.55/K&N/Flowmaster 50 series Delta Flow/Westin Black Nerfs/SuperChip/Hellwig Rear Swaybar/Energy Suspension Front Swaybar Bushings and Endlinks/Trenz Billet Antenna
Old May 31, 2001 | 08:08 PM
FordMX's Avatar
Question
I checked out their website and I was impressed with the fact they had a picture of the FIPK installed on a 4.2L specifically. The only concern I had was that their whole marketing draw was that they said their boxes are sealed to draw cold air from fender, however, on the V6, it was just a standard "airaid type" open filter. So my question would be, what would make the voolant going any better than the airaid or AF1?
Thanks,
Chris
1998 F-150 Standard Cab/Long Bed 4.2L V6
  • Fabtech 3.5" Spindles
  • 2" Rear blocks
  • BFGoodrich 295/75R16 AT's
  • Rancho RS 9000's
  • Rhino Bedliner
  • 3.55 Gears
  • Changed pinstripes to gray (come on Ford, did purple pinstripes really look good on ANY truck?
  • Limo Tint
  • Pioneer P-6000 Head Unit, 4 Pioneer 3-Way 6x9's, 800 watt Pioneer Amp, 2 12" Pioneer Subwoofers
  • PIAA High-Intensity Driving Lights mounted in bumper
  • Updated front end to 2001 Black Grille w/ honeycomb, 2001 Chrome bumper, 4x4 Valance w/ fog lights & Tow hooks
  • Clear corners and tail lights
  • 2001 XLT 60/40 Seat
Old May 31, 2001 | 10:44 PM
MechE's Avatar
Post
I think thats just a cool pic so you can see the blue filter that matches their logo colors. If i remember right every engine link has a picture of the actual filter on the actual engine its linked under.
How much are they asking for this plastic tube?
[This message has been edited by MechE (edited 05-31-2001).]
Old Jun 1, 2001 | 07:13 AM
patrickjp's Avatar
Post
same thing as the airaid, my FIPK sits right on the fender wall as well
Old Jun 1, 2001 | 11:27 AM
r0land's Avatar
Post
I find it interesting that they don't have any head on shots of the fipk. You'd think if thier whole marketing draw is about getting cold air from the fender, they would show the front of the filter and not just the side. I think this is just a marketing ploy. I bet the front of the filter is closed off even. In that case, wouldn't it be worse than the fipk with the heat shield? Just an observation.
Old Jun 2, 2001 | 12:49 AM
patrickjp's Avatar
Post
yep, I was thinking the same thing..
There is no tube going into the fender(look at the pic of the complete kit), so that right there is just a marketing bs statement
Old Jun 2, 2001 | 12:58 AM
Y2K OffRoad's Avatar
Thumbs up
I'm afriad that you all are a little confused. They actually make 2 kits, one open filter ala K&N/AF1/AR, and they also make a closed filter cold air kit that goes into the fender.
Look at the F150/Expedition with 5.4, they actually have 2 seperate kits available for it, one open, one closed.
Fact is the open filter kit is the only one they offer for the 4.2 at the moment. Someone might want to send them an e-mail to see if one is in the works.
My New Baby: 2001 F-150 XLT Sport 4x4. 5.4L, S/C, S/S, Bright Red, Dark Graphite Int., 3.55, Class III Tow/Heavy Duty Cooling, 4 wheel disc ABS, Overhead Console, Factory In-Dash CD, Remote Keyless Entry.
Mods: Ziebart Rust Protection, Ford Bug Deflector
Future Mods: Running Boards, Superchip, Air Force 1, Cabin Air Filtration, Ventvisors, Spray-in Bedliner, and Retrax.
2000 Polaris Sportsman 500, Camo Green, 4x4, 499cc 4-stroke, independent suspension, shaft drive, 4 wheel disc brakes, etc.
Old Jun 2, 2001 | 04:27 PM
mike150's Avatar
Cool
The filters do have an open end to them that fits up against the fenderwell opening.if you look in their filter sections you can see.It seemed the volant had a good mounting system.I got the Volant for 205.shipped.Does the airaid or air force1's have an opened end filter?I guess if the 4.2 needed a cool air box then I would think at least one of the manufacturers would make one but they don't.would not be hard to make a box like k&n makes for their gen.II kit.
