2,000 RPM in Neutral
Old Sep 10, 2000 | 01:30 PM
F150Y2K's Avatar
Post 2,000 RPM in Neutral
This problem started about a week ago. I have a 5 speed and whenever I'm on the freeway and then exit, my RPM's stay at 2,000 even when I shift out of gear and have it in neutral. I roll up to the light as if I had my foot on the accelerator. And then when I get going again, it's as if I don't take my foot off the gas pedal. I change gears at 2,000 RPM and when I'm going from 1-2, 2-3, 3-4, the RPMs will stay at 2000 even when I have the clutch in and no foot on the gas. Have an idea of what the problem might be?
2000 F150 V6 4.2L 5spd 3.55 gears > SuperChip EGJ3 > FlowMaster Exhaust
> KenWood 600W Powering 2 10" MTX 6000s in ThunderForm Stealth Box > KenWood DPX600 DoubleDin CD/Cassette > CB/PA System > Matrix HID Headlights and FogLights > Bug Deflector > Clear Coroners > Window Vents and Tint > Nothing but Texaco PremiumGasoline-CleanSystem3 > SideMarker Turning signals > Indiglo Gauges > Black TailLight Covers > 55w Reverse Rectangle Lights > Strobe lights in headlamps / Turning Lamps / and TailLamps > AirAid (finally) > Blue Neon Lights inside bottom of front and back feet area > Altezza Lights
In the Future:
> 4" suspension lift and 2" body lift
> 35x12.5x16 MT BFGoodrich > 4.56 Gears
Old Sep 11, 2000 | 02:34 PM
BigBunnell's Avatar
Lightbulb
Pull the plastic cover off of the trotle body, and check the throttle cable and linkages for binding. Thats probably the best place to start
Old Sep 11, 2000 | 02:35 PM
BigBunnell's Avatar
Lightbulb
Old Sep 16, 2000 | 08:53 PM
stevenf150's Avatar
Thumbs up
Try to run the truck with out the superchip, that may be your problem. It all boils down to clean the contacts on the EEC-V computer.
DO NOT REMOVE THE GOLD ON THE CONTACTS!
Good Luck
1999 F150 XLT 4.2L V6 5 speed man white
[This message has been edited by stevenf150 (edited 09-16-2000).]
Old Sep 18, 2000 | 10:31 PM
F150Y2K's Avatar
Talking
Thanks guys for your replies. Big Bunnell hit it right! I took the throttle cover off and there was all kinds of build up on the cable. I sprayed it with some WD-40 and cleaned it right off. Thanks again for everything!
