2008 F150 4.2l V6 MORE POWER
Old Jun 28, 2010 | 02:19 AM
97XL's Avatar
Dual 16" fans will be fine..you can use the same belt. You are just taking the fan/clutch assembly off of the pulley.
Old Jun 28, 2010 | 10:51 AM
FlashmasterK's Avatar
The only time you will need a new belt is if you install UDP's as well as the efan.
BTW, truck is in the shop getting the Mark VIII installed. I know alot of people say its easy, but if something goes wrong, I want to be able to take it back in and have someone to blame besides myself! And mind you, this is the FIRST time I have not been a DIY project
Old Jun 28, 2010 | 03:40 PM
The pulley stays, because it also drives the water pump. You simply remove the fan from the pulley.
Old Jun 28, 2010 | 04:02 PM
Pitbull_Rott's Avatar
k, thanks
Old Jun 29, 2010 | 09:50 AM
UDP is in. Id say about 5 more HP to the wheels. You notice it the most when you are accelerating (obviously)
Old Jul 9, 2010 | 09:54 AM
sonicwrx's Avatar
im a lil lost guys, sorry, what are asp and udps
Old Jul 9, 2010 | 10:54 AM
ASP is the company that makes the udps.
UDPS>>Under drive pulley system.
Old Jul 9, 2010 | 11:05 AM
sonicwrx's Avatar
oh... makes sence thanks
Old Jul 9, 2010 | 11:13 AM
sonicwrx's Avatar
so do all these mods make a noticable difference or just on a dyno sheet?
Old Jul 9, 2010 | 12:15 PM
sonicwrx's Avatar
Old Jul 9, 2010 | 02:58 PM
BlueOval_Man's Avatar
Programmer, UDP, E-Fans probably 20 HP, slight noticeable difference.
Old Jul 9, 2010 | 04:50 PM
sonicwrx's Avatar
well what about mpg's. better or worse?
Old Jul 9, 2010 | 05:27 PM
if you dont drive it like you stole it you will get noticably better gas mileage. but as it goes, more power = stand up on it!
Old Jul 13, 2010 | 04:09 PM
I am getting about 1 mpg better with the UDPs and Efans in. I am also driving alot more aggressively than I normally do cuz I want to play around with the new setup. So once I go back to driving a litte more conservatively I expect that number to go up a little more.
Old Jul 15, 2010 | 08:05 AM
sonicwrx's Avatar
so i guess my other question is, do you feel for the gains you aquired (mpg & hp) is it worth it money wise. i would hate to sink 1k or so and feel like it was all a waist.
