Battery light comes on at about 4000 rpm
Old Jun 13, 2010 | 12:14 AM
Battery light comes on at about 4000 rpm, regardless of load or accelerator position or gear.
Most likely cause? Alternator?
Battery is less than a year old, belt is not slipping.
Old Jun 13, 2010 | 12:21 AM
It's protesting that many RPMs!
Old Jun 13, 2010 | 12:28 AM
Yes, it would be the alternator giving over voltage... it's more than likely the voltage regulator going on it's wayside.
Old Jun 13, 2010 | 12:29 AM
Overvoltage?
Old Jun 13, 2010 | 12:37 AM
http://answers.yahoo.com/question/in...4003223AAnAr3w
Old Jun 13, 2010 | 12:00 PM
I plugged a DVM into the lighter socket this morning and took it out for a drive - it's running at 13.96 volts. When the battery light comes on, it drops to 12.1. That's undervoltage, not overvoltage. Still think it's the alternator?
Old Jun 14, 2010 | 11:12 PM
It might be... remember my taunting thread about my insane alternator/pulley problem? I'd say replace it.
Get a NAPA "new" alternator... it's got a 3 year warranty on it, plus the design of the alternator is much better than the Motorcraft one, especially under heavy draw. There is no whine.
Old Jun 15, 2010 | 01:03 AM
Raptor05121's Avatar
That's your power steering pump. A common problem on all Ford vehicles.
Old Jun 15, 2010 | 01:19 PM
It's over at Ford right now, and it is the alternator. Service advisor just called.
Old Jun 15, 2010 | 03:37 PM
Wow, you let a dealership work on your truck? I never thought I'd see the day
Old Jun 15, 2010 | 05:13 PM
I don't do my own work any more. The dealer here is excellent and reasonable - $79.85/hr labor. I don't use them for stuff that independents can't screw up like oil changes, exhaust, shocks, brakes, and tires though. I go to specialists for that stuff.
WDS, reman alternator, labor, tax - $340.
Old Jun 15, 2010 | 05:22 PM
PS whine is different. Plus I knew where it was coming from. And replacing the alternator and pulleys solved the problem.
Told ya.
Not bad.
Old Jul 2, 2010 | 01:59 PM
streetracer1232's Avatar
generators in ford terms are suppose to put out 13 plus anything below and its time to replace however anything over 15 its over charging and yes you can have a bad new generator i have seen it ( under any load it has to charge between these levels ). they are not hard to change but i do recommend motocraft brand not cause i am a tech but i have had people come in with a new generator installed and it was bad or went bad very quickly
Old Jul 2, 2010 | 03:12 PM
generator and alternator are two different things
Old Jul 2, 2010 | 03:15 PM
i coulda done an alternator for you while you were out here........
