Dyno Charts
Old Apr 16, 2010 | 01:09 AM
97XL's Avatar
Might be the K&N truck has lower miles on the motor when they tested it. I know mine had about 145000 miles on it when I first dynoed it.
Old Apr 16, 2010 | 03:36 PM
timmypstyle's Avatar
the K&N test truck was a 98, 2nd gear run, 125,287Miles on the clock. 86.88 degrees with the stock run, then with the K&N it says same mileage, was about 3 hours later at 90.74 degrees.
stock ran 166.24hp and with the K&N got 172.39hp
lol my intake came with the sheet when i bought it. i kept it with my insurance report for my T/A wreck and other car info i printed out awhile back. had it beside me in a bin when i read your post lol
Old Apr 19, 2010 | 01:01 AM
97XL's Avatar
Guess my motor is just more tired than I thought, but there are probably tons of other variables that make the numbers look way off, but whatever K&N says I'm still happy with what I've got now, sure beats taking the bus to work.
Old Apr 19, 2010 | 06:13 AM
Fifty150's Avatar
I think K&N is advertising HP @ the crank.
Plug in a ScanGauge II, and see what the HP says.
Old Apr 19, 2010 | 11:54 AM
Raptor05121's Avatar
these are dynos. the HP @ flywheel would be about +40 hp higher anyways
ScanGaugeII isnt accurate for measuring HP, I've gotten mine to say 240 before
Old Apr 21, 2010 | 08:56 AM
at the crank should be about 200hp since that is the engine's rating. these are rear wheel hp numbers altho i wonder about 4x4's. i wonder how much a 4x4 would put down compared to a 2wd.
yeah, plug in readouts....
anyways, here is the whole shabang. this is EVERYTHING the dyno printout says..and exactly how they put it.
DYNOJET RESEARCH
Stock 1998 F-150 4.2L at 2g
stock baseline run. 2nd gear run. 125287 miles
run date 7/8/2005 10:37:41AM
stock.001: 86.88 degrees F, 29.06 in-Hg, SAE: 1.03
166.24@4350rpms
K&N 1998 F-150 4.2L at 2g
K&N intake kit installed. 2nd gear run. 125287 miles
run date 7/8/2005 1:23:21 PM
K&N.002: 90.74 degrees F, 29.05 in-Hg, SAE: 1.04
172.39@4200rpms
Gain of 6.15hp@4567rpms
Old Apr 21, 2010 | 09:44 AM
Originally Posted by timmypstyle
DYNOJET RESEARCH
166.24@4350rpms
172.39@4200rpms
why 2nd gear run? 1:1 direct drive is 3rd gear....
Old Apr 22, 2010 | 10:56 AM
dirtyd88's Avatar
Because K&N said so.
Old Apr 22, 2010 | 02:27 PM
probably so they wouldnt hit the speed limiter. thats my problem. i want to get mine dynoed but my speed limiter is 100 and 4th gear is 1:1(manual) but 100mph is 4k in 4th. so ive been wanting to know if i could use 2nd or 3rd. so far, nobody has said yes, but i dont see how people get their vehicles dynoed in a 1:1 ratio if they have a lower speed limiter.
LOL damn straight!
