fuel rail tool?
Old Mar 11, 2009 | 07:21 PM
rpm9001's Avatar
fuel rail tool?
I'm changing my intake gaskets on my 97 4.2 and need to remove fuel the lines from the rail. Is the tool for this available from a regular parts store, or does ford have a special tool. I'm at that point. something I can get at auto zone / or advance auto? Or a trick to do it with out?
I have the one for the fuel filter is it the same for the rail?
Geo
Old Mar 11, 2009 | 07:34 PM
4play2008's Avatar
well i know on the 5.4L you can just pull on the injectors to take them out.
Old Mar 11, 2009 | 08:00 PM
rpm9001's Avatar
Thanks,
I need to remove the lines from the rail.
Thanks,
Geo
Old Mar 12, 2009 | 01:11 AM
Veteran: Army
I bought the metal ones from autozone and had to return them, there is a set of plastic tools that worked like a charm though
Old Mar 12, 2009 | 06:31 PM
Raptor05121's Avatar
Yeah, I borrowed that 3/16" (I believe) plastic clip releaser from AutoZone and from what I saw, it is the same connector on all the fuel lines. They hold $10 as collateral then when you return it they give it back, so why not go grab it before you start just in case?
Old Mar 12, 2009 | 07:30 PM
rpm9001's Avatar
Thanks,
I actualy had them in my box.. Thanks!!
