Sct
Old May 19, 2008 | 03:52 PM
2007f150xl's Avatar
Sct
Can I order a SCT tuner and use it and then have custom tunes done for it later???also were is a good place to buy one? thanks
Old May 20, 2008 | 01:16 AM
97XL's Avatar
You'd have to email or contact SCT directly about canned tunes for the 04+. I know for a fact they don't have any for the 97-03 v6s cuz I asked. So my Xcal3 has just been sitting in a box for the past few weeks while I await my tunes from Troyer. All you can use it for is as a code reader. If you get it make sure you get the firmware update from their site. And one thing they forget to tell you is how to format the SDcard inside it. That took me 3 phone calls to find out why I couldn't upload a file to it.
Old May 20, 2008 | 07:21 AM
2007f150xl's Avatar
thanks for the info
Old May 20, 2008 | 12:26 PM
04heritage's Avatar
Go to justin @ VMP he will take care of you. If you go to the Chip, Tuner & Programming section you will see everyone is going to Justin or PHP.
It took 2 weeks to get my Xcal 2 from Justin. had one problem with the MPG tune and ended up getting it replaced with a 87 perf. from a local tuner.
Old May 20, 2008 | 08:37 PM
Fifty150's Avatar
Yesterday 12:52 PM
2007f150xl
Sct
Yesterday 10:16 PM
97XL You'd have to email or contact SCT directly about canned tunes for the 04+. I know for a fact they don't have any for the 97-03 v6s cuz I asked. So my Xcal3 has just been sitting in a box for the past few weeks while I await my tunes from Troyer. All you can use it for is as a code reader. If you get it make sure you get the firmware update from their site. And one thing they forget to tell you is how to format the SDcard inside it. That took me 3 phone calls to find out why I couldn't upload a file to it.
No problem for the 2007 truck. With the 2007 4.2L V6 F-150 XL, you will get canned tunes directly from SCT. It would certainly be cheaper if you only buy the tuner without custom tunes. See below:
Old May 20, 2008 | 08:41 PM
Fifty150's Avatar
Yesterday 12:52 PM
2007f150xl
Sct
Yesterday 10:16 PM
X3 Power Flash Handheld Programmer
Part Number: 3000
Key Features:
• Latest Flash Technology
• Pre-Loaded with Dyno Proven Tune Files
• Stores up to 3 Custom Tune Files
• Reads / Clears DTC Trouble Codes
• User Adjustable Features
• Monitor Popular External Sensors
• 2008 Models Supported
• Built-In High Speed Datalogging
User Adjustable Features:
• WOT Fuel Adjustment • Idle RPM
• Spark Adjustment • Transmission Shift Points
• Axle Ratio • Fuel Injector Size
• Tire Size - Rev / Mile • Air Intake Selection
• Cooling Fan Temps • Traction Control On / Off
• Rev / Speed Limiters • Two StepOn / Off RPM
* Not all adjustments available on all vehicles
Pre-Loaded Dyno Proven Tune Files:
The X3 arrives Pre-Loaded with DYNO Proven tune files that INCREASE HORSEPOWER, TORQUE and EVEN FUEL MILEAGE!
Stores 3 Custom Tunes:
The NEW X3 stores up to 3 Custom Tune files which can be loaded by any of SCT’s Custom Tuning Dealers World Wide!
Large Backlit Screen:
With a HUGE Backlit display, the SCT X3 Power Flash makes it EASY to read the Built-In Data Logging or Real Time Monitored Vehicle Data, view popular sensor data such as EGT, Air / Fuel Ratio or any other 0-5 Volt source via the Dual Input Analog port.
Read / Clear DTC Codes:
Using the X3 Power Flash Device, you can now Read, Clear & Diagnose Trouble Codes without the expensive diagnostic fees charged by dealerships or your local garage.
MSRP: Description: Part Number:
$479.00USD Ford X3 Power Flash Device 3000
Order Now
Old May 20, 2008 | 11:35 PM
2007f150xl's Avatar
thanks for the info
Old May 21, 2008 | 03:06 PM
04heritage's Avatar
Xcal3 - $385
Xca3 with custom tuning - $400
custom tunes - $50 per tune (if you decide to get custom tunes later)
http://www.vmptuning.com/store/index...parent=66&pg=1
Give Justin @ VMP a call and ask him if he can get you a tune for a stock truck and tunes for what ever you decide to install.
