What oil?
Old Mar 26, 2008 | 11:10 PM
4.2L_Guy's Avatar
What oil?
What oil do you guys use in your v6
i use nothin but the motorcraft 10w-30 synthetic blend. with a Fram oil filter.
what do you use?
Old Mar 26, 2008 | 11:14 PM
BlueOvalFitter's Avatar
Thumbs up
Motorcraft 5W20,Motorcraft oil filters!
Old Mar 26, 2008 | 11:39 PM
04heritage's Avatar
NVM its barried already.
Old Mar 26, 2008 | 11:44 PM
Question
What?
Old Mar 26, 2008 | 11:46 PM
04heritage's Avatar
The million other "What oil is best" threads.
Old Mar 26, 2008 | 11:49 PM
Talking
The search feature must be broke!
Old Mar 27, 2008 | 08:29 AM
Mobil 1 EP 5w20 and a Mobil 1 filter.
Old Mar 27, 2008 | 08:48 AM
Octane36's Avatar
what do you use?
You should be using 5w-30 with a Motorcraft oil filter. Those Fram filters are junk.
Old Mar 27, 2008 | 10:06 AM
4.2L_Guy's Avatar
haha who said this is a what oil is best thread?? im asking what oil you use... and if you think the oil threads are dumb dont come to them and start posting becasue i wouldent want you to read to much about oil. but anyways. y what is wrong with the fram filters?
i used to use a motor craft filter. but i just wanted to change things up a bit.
and also y 5w whats wrong with 10w
Old Mar 27, 2008 | 10:24 AM
ChrisT's Avatar
It's not that oil threads are dumb, it's just that the topic is brought up quite often and simply searching on the subject will answer any questions you may have about "what oil do you use"... "which oil is best"... "which filter".. etc.
I used to use only use Fram filters until I read some really good information on this site about why they are not the best. *Hint* search "anti drain back valves" and you will find one of the many reasons of why Fram is not recommended. Good luck.
Old Mar 27, 2008 | 10:45 AM
4.2L_Guy's Avatar
ok thanks.
Old Mar 27, 2008 | 10:49 AM
Raptor05121's Avatar
why 5W whats wrong with 10W?
Because our 4.2L is designed around 5W-30 oil. 10w is more viscous and takes a bit longer at startup to coat everything. Also means the engine has to work harder when its cold outside. I highly recommend you go back to 5w ASAP.
Old Mar 27, 2008 | 10:50 AM
4.2L_Guy's Avatar
well anyway sry i asked dint know that it would be such a bad thing to ask... but i guess i was wrong. so anyway. sry but i dint see any oil questions on the v6 forum so thats y i asked it.
Old Mar 27, 2008 | 10:55 AM
Well your still a junior member so you have 5 more "im a newbie" saves.
you'll get used to it. welcome to the site
Old Mar 27, 2008 | 12:19 PM
04heritage's Avatar
I don't know about you guys but my truck says 5w-20.
So, normally I use Mobil 5000 5w-20 with a K&n filter.
