frontend Vibration and squeak from left front.
Old Jul 19, 2006 | 07:43 PM
badtothebone86's Avatar
Question frontend Vibration and squeak from left front.
I have a 2001 F150 and the front end vibrates between 40 and 42 mph. When I go slower or faster then 40 to 42 mph it goes away. I am not sue what it is. Can yall tell me what may be the problem? Also my left front sqeaks. I am not sure from what. My brakes pads still look new. I am not sure if it is my wheel bearing or not. Can yall tell me what could be wrong? Thanks.
Old Jul 20, 2006 | 12:31 AM
BlueOvalFitter's Avatar
Exclamation
Does it squeak when you turn the wheels side to side?If so your pitman arm might need grease.If it's factory it won't have a grease zerk.You can buy a grease needle and grease it that way.That should stop the squeak.
About the vibration,it could be a bent rim or an unbalanced tire or tires.Ran into any big potholes lately?
Old Jul 20, 2006 | 07:01 PM
My tires are ballanced and my rims arent bent. What else do you think it could be?
