Stall while turning.
Old Sep 6, 2003 | 01:46 AM
F150Forever's Avatar
Question Stall while turning.
45K miles on a 2001 4.2L.
The truck stalls when slowing down to go into a turn after steady driving for 30 minutes or more. This only happens after a long drive at constant speed. Around town is no problem.
Any ideas?
Old Sep 7, 2003 | 07:31 AM
BlueOvalFitter's Avatar
When did you last change the fuel filter?
Old Sep 7, 2003 | 11:33 PM
Changed fuel filter about 10K miles ago. I can't figue it out. The problem is almost like carburator float problems. I used to have a carb. engine that would do the same thing when going around corners and it turned out to be the float. Maybe It's the injectors, but I don't think so - not with only 45K on the engine that has mostly highway miles (60 mi/hr. most of the time).
Old Sep 24, 2003 | 11:49 PM
Found my problem,
The DPFE was bad. Replaced and now no stalls anymore.
The part number on the original part was YYF1E-9J460-AD. I got the replacement which is 2F1Z-9J460-AA. I think this is the enhanced part due to all the falures of the original.
I got the part for $49.99 at http://www.fordpartsnetwork.com/
Old Sep 25, 2003 | 12:07 AM
Correction: The original part # was YF1E-9j460-AD
Old May 21, 2004 | 07:32 PM
Joe Styles's Avatar
Were is the DPFE located.
Thank's Joe
Old May 21, 2004 | 09:31 PM
temp1's Avatar
Thank's Joe
On the 5.4L engine...
Old Aug 27, 2012 | 09:22 AM
kepaloha's Avatar
That is the exact same problem I have, when I turn a corner my RPM's drop and almost stalls most of the time and other times it will actually stall.
Would that DPFE Sensor also cause a rough idle when sitting at a stop light?
