odometer? un-hook?
Old Nov 17, 2002 | 07:14 PM
toddyman88's Avatar
Registered User
Lightbulb odometer? un-hook?
hey guys, i just bought my 02 f-150 fx4 in july and allready have 14,000 miles on it. at this rate warranty will be an after thought before a year is up! any insight on unhooking the odometer? where is the plug located and will the tach still operate? thanks!
Old Nov 17, 2002 | 08:26 PM
Mark Kovalsky's Avatar
Doesn't that sound more than just a little dishonest to you?
Old Nov 17, 2002 | 08:33 PM
Dustoff's Avatar
Wink
Try walking more...
Old Nov 18, 2002 | 07:54 AM
LE PEW's Avatar
Ethics and morality issues aside I think the computer might still be tracking the mileage some other way?
Walking is cool too but my bicycle gets me around pretty well.
Good luck.
Old Nov 18, 2002 | 02:52 PM
ccnseven's Avatar
I don't know if they are similar but I have a 92', and the vss (vehicle speed sensor) plugs into the rear end on the axle tube on the driver side. I unplugged mine for about 4 years. The tack worked fine but it affected the cruise control, speedometer, odometer and the abs light stayed on.
Old Nov 18, 2002 | 03:07 PM
Raoul's Avatar
Certified Goat Breeder
25 Year Member
Question
Does anyone know the fewest lift points needed to remove all four wheels at once?
Also, what is the quietest jack on the market right now?
Another thing, is it possible for me to remove my battery without going to all the trouble of raising the hood?
If I did want to remove my battery from underneath, are there just wing nuts there or what size socket would I need?
and if I can do this, just wondering what year models could I do this too?
(I mean if I bought another year other than the one I have and I wanted to remove the battery without going to all the trouble of raising the hood.)
If I didn't have my key with me and I needed to get into my truck real quick, what would be the fastest and also the quietest?
What does gas taste like?
Old Nov 18, 2002 | 04:35 PM
Cheebmonkey's Avatar
Let me see here
Raoul let me see if i can answer your questions
1. none...it really depends on how fast you are driving?
2. Sure if you use a air chisel
3. Whats a socket
4. all of them, its better if you don't own the truck
5. Put a big pillow against the centre of the rear window and kick it through, it keeps the sound and mess inside
6. Like rotten Oranges...or a stripper I knew once, funny story actually I was......oh never mind.
toddyman88, go buy a new gauge cluster and pop it in....boom 14000kms gone. By the way thats fraud and its bad, say hello to Ben when you get to jail......all new fish meet Ben...Ben Dover.
Old Nov 18, 2002 | 07:00 PM
toddyman88's Avatar
Registered User
Angry
Thanks cnnseven I will check into it. Not bad, got one reply from a goatherder aspiring to be part time commedian, a ford engineer.....(nuff said), an ethics major and some other guy that must not live more than a block from where he rides his bike too. In case all of you have forgotten, Texas is a mighty big place and some of us prefer to live outside the smog and have to actually drive the vehicle we pay on and not just admire it from afar and ponder for a month at a time what brand filter to purchase next. I am as far from being a dishonest person as one can get but am a firm beliver that these trucks cost about twice what it takes to build them and and a third of what the crook at the dealer is selling them to me for. Think he would tell me if that fender had been painted before I buy OR offer to fix the intake gasket on my 97 4.2 when he knows all good and well that it is a engineering foul-up? Yes Mr. Ford engineer you know what im talking about! If you guys want to view me as being dishonest for trying to get a little extra warranty from something that WAS and IS being engineered to last just long enough to be out of warranty when it goes to crap then feel free, BUT dont let the glow of your halo blind you when you look in the mirror! Thanks for your support.
Old Nov 18, 2002 | 07:11 PM
PhillipSVT's Avatar
Un-hooking the odometer is like un-hooking your "man hood", its just plain wrong.
Old Nov 18, 2002 | 07:28 PM
Raoul's Avatar
25 Year Member
Originally posted by toddyman88
...I am as far from being a dishonest person as one can get...
I feel sorry for your two boys.
Old Nov 18, 2002 | 07:36 PM
MitchF150's Avatar
Question
I don't think these engines or trannies would know what to do if they didn't have that speed thing connected. The whole computer seems to basically run off of that speed gear. As well as a whole host of other sensors and stuff.
My truck shifted funny and just didn't seem to run right when I put on taller tires and didn't change the VSS gear to compensate. Sure, I was putting on less miles, but I didn't like the way the truck ran. I can only imagine how bad it would have run if it was disconnected all together....
Maybe just disconnect it and see what happens??? If it runs good, well, you've got your scam. If not, then you know someone already thought of that trick and that's why you can't do it.......
Old Nov 18, 2002 | 07:38 PM
GreenBuck50's Avatar
I bought my 98 F150 in mid August and have only put about 3,500 miles on it even with some trips. Just had to put that in, and also it is dishonest to cheat your warranty, not to mention against the law, even though thats already been mentioned, I felt the need to mention it again.
Old Nov 18, 2002 | 07:52 PM
toddyman88's Avatar
Registered User
AMAZING HOW LOW A "MAN" WILL STOOP JUST TO GET A CHUCKLE.
THANKS MAN.
Old Nov 18, 2002 | 07:58 PM
Raoul's Avatar
25 Year Member
No chuckle intended.
As the twig is bent, so grows the tree.
Old Nov 18, 2002 | 08:02 PM
toddyman88's Avatar
Registered User
MITCHF150, HOW MUCH BIGGER WERE THE TIRES YOU PUT ON WHEN YOU GOT THE PROBLEMS? THAT IS MY NEXT ADDATION AND HOPE TO NOT GET THE SAME RESULTS.
