Use of the overdrive switch on E4OD
Old Aug 23, 2011 | 11:31 AM
  #31
Originally Posted by adrianspeeder
Never said he did, just makin' sure he doesn't have a C6 truck.
According to YOUR transmission information page, the only trucks that used the C6 after 1990 were the F-250 and up.
Old Aug 23, 2011 | 11:33 AM
  #32
Originally Posted by pdmoney
I discovered someone must have changed the shifter in my truck! This is my first F150 so I didnt know what I was looking for/at. I put some pictures of my dash/shifter here: http://pdmoneyf150.blogspot.com/ and with the help of steve_83 on supermotors I was able to figure out what was going on. Thanks for all the replies. Looks like I will be looking for a shifter or rigging another switch on the dash to go along with the TC lockout mod.
The TCS is simply a momentary switch that connects R/Y to T/W. The TCIL is an LED from R/Y to W/LG, but it's not necessary for the button to work.
I don't know about the 96, but I do know that the 1990's with E4OD had the OD button on the dash, not the shifter.
Old Aug 23, 2011 | 06:10 PM
  #33
MTM Ford's Avatar
My 96 with an E4OD had it on the shifter.
Old Aug 24, 2011 | 10:29 AM
  #34
adrianspeeder's Avatar
From just my research so far. Was hopin to expand the lineup, but looks like he got junkyard swapped.
Those were '89-'91 trucks. '92+ E4OD trucks got the shifter button.
Adrianspeeder
Old Aug 24, 2011 | 08:46 PM
  #35
sharkins's Avatar
Originally Posted by MTM Ford
That's true. My 04 shifts into OD around 45mph. If locked out of OD it locks the TQ at 35-37 mph whichs keeps the transmission cooler. I'm still not sure why Factory Tech thinks the OD button is useless unless towing. IMO it keeps the tranny "healthier" when used correctly. A transmission only has "so many shifts built into it"
Mine is equipped with the Super Engine Cooling package (two-row radiator, transmission cooler, power steering cooler), so that helps keep the transmission cool.
Old Aug 24, 2011 | 09:37 PM
  #36
sharkins's Avatar
Are you sure you have an E4OD? Count the pan bolts.
Or does your shifter display simply have PRND21 instead of (D)?
Adrianspeeder
It's 20 pan bolts on the E4OD, and 14 on the 4R70W.
http://www.badshoeproductions.com/trans.html
Old Aug 25, 2011 | 10:54 AM
  #37
tbear853's Avatar
My first Ford polide car to have the button was my '98, then a 2000, then my last car .... a 2006 which I turned in when retired at 86K Jan 10 and the guy who has it now has near 150K on it and still she's working great ..... and I used the button all the time in each on them.
I used it if anticipating a kick down to 2nd for acceleration by kicking it out of OD first before hitting WFO as it's not good to have her kick down from OD all the way to 2nd in low speed passes.
I also used it for engine braking to preserve brakes, and to prevent hunting in 35-50 range. The state supplied brakes, etc .... but I wanted the brakes cool and in good shape when needing to slow from 120-130 to 45-50 in a hurry before entering that curve there at the foot of the mountain next to the river .... and other places.
If the engine or trans goes out, persuit over. If brakes go out, could be much worse. Neither of those cars ever had a trans problem. I used the gear lever to do same thing in several Chevy Caprice police cars from 1986 up until I got the '98 CVPI to do same things.
I use the button in my personal '01 Mercury GM and my '95 4.6 T-Bird and my '07 FX4 Scab 5.4. much the same way ... except no high speed persuits and responses ..... In the '85 T-Bird we had from 1986-2009 and my '92 T-Bird Sport with AOD I used / use the lever. Brake life is greatly extended and I don't ever have warped rotors.
