Where can I get a speedometer gear?
I want to correct my speedometer by changing the small gear in the trans, but Ford can't get me the correct one. I'm running 4.56 gears and 35" tires and an E4OD trans. I figured a gear for a truck with 4.10's and stock tires should get me close, but Ford says they don't make one for the E4OD and 4.10 or 3.73 gears. The only thing they listed was for a C-6 trans. Does anyone know where I can get a gear? My factory ratio was 3.08.
Sorry, my truck is a '92 Flareside 4x4 with the 5.8 liter engine. It has the OD cancel switch on the shifter. From what I've read, it must be an E4OD. Now that I think about it, the sensor or cable (whichever it is) should be on the tailshaft of the transfer case, not the transmision. So if thats the case, I could use a gear from a c-6 4x4 4.10 equipped truck, if they use the same transfer case. Hmmm. I'm gonna go crawl under my truck and investigate.
OK, now I'm baffled. I crawled under the truck and couldn't find anything. No speedometer cable, no pulse generator, nothing. Just the 4x4 indicator switch on the txfer case, the PNRD selector switch on the trans, and the electronic trans control wires. Nothing that looked like it could be removable with an interchangable gear on the inside. Does the E4OD use an internal pulse generator, meaning the trans must be torn appart to change the gear? Has anyone run into this before? BTW the t-case is a Borg Warner.
Basically your setup (4x4) is the same as my 89 F-150 4x4. Have you checked the
www.ford-trucks.com
They can give you more instruction than I can...
p.s.-Yep your tranny is the E40d.
www.ford-trucks.com
Have you tried a good speedometor shop. We have one here in Tucson that took care of my friends F-250 and it is dead on now.
97 F-150, 2WD, Reg Cab,Flareside,Dk Toreador Red, Windsor 4.6, Magnecor 8.5mm wires, Bosch Plat +4s, 3.55 LS, EGR Bug Deflector, ******* Bed Cover, Bed Liner, XL Full Length Running Boards, Air Aid Kit, Gibson Single Out Cat Back, Superchips, TransGo Shift Kit, Hellwig Rear Sway Bar, Hellwig 2500# Overload Springs
