What oil to use in 4R70W tranny?
Old Jul 23, 2002 | 10:20 AM
Truck's Avatar
I went to AutoZone looking to buy some transmission oil for my truck and noticed they only had of two types of Mercon V and they were both synthetic. I called Ford and they said they use non synthetic Mercon V oil. The manual says to use Mercon V it does not say anything about synthetic. What to use?
Old Jul 23, 2002 | 01:30 PM
seabass55's Avatar
Mercon V is actually a part synthetic fluid....aslong as it conforms to Mercon V specs then buy it. My past three vehicles had 4R70Ws and I used $2.xx a quart stuff from walmart and changed fluid every 20K. No problems.
Seabass
Old Jul 23, 2002 | 01:32 PM
NJFF-Screw's Avatar
I hate to sound ignorant but how can you tell which tranny you have?
Old Jul 23, 2002 | 03:19 PM
terry w 123's Avatar
Unfortunately you have the 4R70W trans, thats all ford puts in the 150 trucks anymore unless you buy the 3/4ton f150 which you cannot get in the screw.
Terry
Old Jul 23, 2002 | 06:40 PM
Neal's Avatar
Cool
HI!... I've been using REDLINE D4 full synthetic tranny fluid for about 2.5 years now and have no complaints.
Old Jul 23, 2002 | 06:57 PM
Mark Kovalsky's Avatar
You can use any MERCON V fluid. Ford does not make any recommendation about dino, blends, or full synthetics. As long as it says MERCON V it is fine for the 4R70W.
Mark
Old Jul 24, 2002 | 01:12 PM
Truck's Avatar
Thanks for your responses
Old Jul 24, 2002 | 10:25 PM
NJFF-Screw's Avatar
Terry w 123,
Thanks for the insight.
Truck,
Sorry to jump into your thread like that.
Pete
Old Jul 25, 2002 | 02:02 AM
mf150's Avatar
You can tell which tranny you have by looking on your driver's side door sticker.
Old Jul 27, 2002 | 03:06 PM
Galaxy's Avatar
What would be the difference/benefits between an actual Mercon V fluid and a "universal" fluid that meets Mercon V specs?? Synthetic or otherwise.
Old Jul 27, 2002 | 03:48 PM
TroyK's Avatar
well, i'm not sure about differences and or benefits...but my owner's manual says not to use the universal fluids...mercon V only for the 4r70w... when the manufacturer says something like that i'm bound to follow that advice.
Old Jul 27, 2002 | 03:55 PM
Galaxy's Avatar
I just went and looked at my manual (2002 5.4LSCrew) and it said the opposite. Mine said you can use a universal fluid for Mercon V but not to use one in a transmission that calls for Mercon, even if the fluid meets Mercon specs. Didn't say anything about not using a universal fluid in place of Mercon V. Not trying to start anything but I read it three times to make sure I read it correctly. Just trying to see if there is a performance or other difference between the two.
Old Jul 27, 2002 | 04:33 PM
TroyK's Avatar
oops, you're right. i had it *** backwards. anyhoo, mercon V was specified for the 4r70w to help eliminate torque converter shudder. i'm not sure how well dual useage fluids are at keeping torque converter shudder minimized...
Old Jul 28, 2002 | 01:09 AM
Galaxy's Avatar
Well, I guess it can't be too bad or too big of a difference. Everyone swears by Amsoil fluid and it is a "universal" fluid that meets Mercon V specs but it is not solely a Mercon V fluid.
Old Jul 31, 2002 | 12:18 AM
mf150's Avatar
D4 Redline is good stuff. Mercon is good if you want to change it every 30,000 mi.
I will be switching to D4 at my first change period ( 30,000 mi.).
