4R75E trans help
Ok thanks again guys I used a brand new drain pan and dropped the pan. Looked at the screen it wasn’t seated right when I put the new one on. Running great now. Thank you everyone for the help
QUOTE=Mark Kovalsky;5265202]Resetting the computer can't help this. There is NOTHING electrical that can cause this. It has to be something mechanical.
Install a gauge in the test port on the driver's side of the trans. Chances are that there is no pressure. That can be caused by a torque converter that isn't seated properly, very low trans fluid, or a missing internal filter.
According to factory manual that screen can be discarded once inside the valve body.
