2000 ford f150 Transmission problems
Old Sep 13, 2020 | 08:34 PM
Isaac.gore89's Avatar
Transmission wont move under load ie tires are on the ground but when I jack up the rear end with the tires off the ground the transmission turns the wheels just fine through all gears what could be causing this?
Old Sep 13, 2020 | 08:55 PM
Have you checked the fluid? If the OD OFF light is flashing, read out the OBD2 codes with a scanner that can read Ford transmission codes.
Old Sep 13, 2020 | 09:08 PM
fluid is good, no codes I just had the tc and clutch packs replaced filter is good pump is circulating fluid cooler is clear of debris I was told the transmission is in excellent shape other then the clutches needing replaced
Old Sep 14, 2020 | 09:24 AM
Mark Kovalsky's Avatar
When you try to move it does the engine stay at idle speed or does it rev up?
Old Sep 14, 2020 | 10:07 AM
it revs up but only to stall speeds its like it wants to move but doeant have enough power to move
