2005 F-150 No Reverse
Hello, I need help!!!! I have a 2005 F-150 5.4 4x4 automatic transmission 4R75E.
To start out I lost overdrive would come and go. So I replaced overdrive sovo and fixed it.
Then maybe 10 miles later reverse went out. With no warring didn't slip or make any noise. Just went to neutral.
So I took out trans and took it apart to find clutches and stills on the reverse gear welded.
So I overhauled with all new- clutches, stills, both bands, bearings, bushings, all rubber seals, torque converter and the new overdrive sovo.
Put it back and no reverse. Shifts 1,2,drive good and then overdrive hard.
Can anyone please help me with this.
Thank you
Thank you
