New transmission installed. Drives in reverse not forward.
I own a 2002 F150 with the 4.2L V6. The transmission went out about 2 months ago and I just finished installing the new one. After installing I was ready to test drive. In reverse the truck drives as soon as I let off the brake like it's supposed to. When I put it in drive though, it will not move when letting off the brake and doesn't move until I push the gas heavily and even then it just barely moves. I'm not a huge car guy so I'm looking for ideas on what to look for that I may have done wrong or not hooked up properly. Any tips are much appreciated. Thank you.
That's too bad. If it flashes, that indicates a transmission fault which can be read out with an OBD2 scanner. You may want to scan it anyway and see if there are any transmission codes, you need a scanner that can read Ford transmission codes. Cheapest way is if you have an Android phone:
https://scanneranswers.com/obd2-scan...mission-codes/
Rant off.
